I have had over 25 cars in my life BUT the windscreen reflection on my 34 is something else, never had anything like this before. Had to change the undies a couple of times when I got home, lol
Always drive with sunnies on during the day.
I drive a lot early in the morning on a bendy road, come out of, or into a corner into the sun and the road disappears, I mean , gone! white out!
Cleaned inside and out, run the washers when it starts to look dirty ish, use the sun visor and still scary. :yes:
I put a black mat out of the Tiida on the dash and that helps a lot, 50% better but that goes where it wants when you accelerate hard . Just ordered a R34GTR dash mat and and I am sure it will help the glare.
Just wonder if some type of tinting could help or maybe it has been used and is the problem because it has scratched up or something ????
Funny you brought this up. I had the exact same thing happen today, first time ever I was driving blind.
The windscreen just needs a proper clean. Sometimes you need to re do it over and over again until streaks and glare are gone.
What do you use to clean your inside? Most products leave a film behind that will intensify glare.
Hi Peter,
Use - 0000 fine steel wool you can get from Bunnings on the outside of your windscreen.
Give it a good rub over.
Then use Rainx following instructions.
Lastly get a 10-15cm sun strip for your front windscreen.
  • Like 2
I have to say , driving blind(not drunk) is one scary Mother f er
Some of the protectant products for the dash are too shinny, I think the angle of the windscreen and how close it is to the dash might also play a part ?
I have some glass polish and I will try it in the morning and see how that works ?
I have the Bosch GEX 150 Pro sander/polisher and all of the different microfibre cloths, pads, polish and a glass cleaning kit. Think I will have to get serious with it :)
Just did the drivers side earlier this morning and went for a run and it is a bit better but the mat I covered the dash with works the best to help stop the reflection.
I will have the full R34GTR dash mat coming early this week and I will do a full windscreen clean and polish and see how it goes.
The windscreen is only 1 hand width away from the dash at the front of the dash, on the Tiida, it is 1 hands width close to the windscreen and I have no reflection problem, I just wonder if the dash being so close to the windscreen could cause the reflection ?
This is why I HATE silicon on the interior.
Way too much glare.
Also, watch the glass polishing, as it can cause warped vision if you create high/low spots.
Sun in your face is easy, just drop the sun visor but that reflective glare is something else. It is only very early or late driving, no problem at other times. Maybe my eyes are stuffed ?
But , I have never had this type of glare in any other car and have used Armor All?
In the 34GTR it makes everything disappear, bloody scary, better than a radar camera to make you drive UNDER the speed limit :)
Now I have to watch out if I polish it unevenly , cant win, lol
I use Repco Eclips , not as shinny as Armor All but still shinny
Going to get super fine 0000 steel wool later and also try the Rainx
But I think the Dash Cover will do the trick and it has the cut outs for the Aircon etc. I will take a couple of pics and post them, should have it tomorrow.
Thanks
cleaning the windscreen wont help much, its only good if its hazy and affects your vision at night, but doesn't appears to be the case
its probably just a fundamental design issue with the car - shape of the dash and the angles between dash, windscreen and driver's head
Plastidip the dash matt black :P.
Funny you said that , got the dash mat today and stuff me if it is not a Nylon or similar and Fn sparkles when the sun is on it. I will go for a run in the morning and see what happens.
Plastidip, have to look it up ??????
If it is crap I was thinking a matt black spray might be ok, not too sure how it would look or smell , should be OK when totally dry ?
I think the design is the issue, windscreen very close to the dash and maybe since I am short I am closer than most ?
plasti-dip is a mat black spray.
AFAIK, its a liquified rubber.
You can pull it off fairly easily too.
Probably do the job, but sounds like it might look a bit rough sitting on top of the dash ?
The dash mat is not a flat surface, some sort of carpet like material. Might try some black dye first if the mat causes glare, could always try the plasti-dip after if needed and if it comes off easily there should not be a problem if it looks a bit off :/
Let you know how the glare is tomorrow and take a pic, the mat itself looks , well OK ish but better than I thought it would look :)
Or you could use a pillow......jus sayin'
Hahaha, first car was a 1936 Dodge @ 15, needed 2 pillows,1 to lift me up to see over the bonnet and the other so I could work the clutch, brake and go go, so do not knock the worth of a good pillow or 2, lol
Had a run this morning but left a bit late but there was no glare with this dash mat, have to do it again earlier or later this arvo to get a true result
As you can see from the pics, there are cut out for the aircon and passenger airbags. So at least they put some thought in making it.
Oh gawds one of those mats. I'd spray the mat a, erm, matt colour to remove the shiny-ness.
That is the plan if it does not cut the glare down and with that Nylon type matting I guess it will not be too good. I think I will try the dye first to see how it goes ?
Have you had one of these, hard to tell when you see them on the web :/
Fit OK
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
