19 minutes ago, Guest Alex said:
The search function doesn't seem to be working for me in the for sale section.. -_-
Search is still indexing, it'll be a few hours before its fully available.
57 minutes ago, Kinkstaah said:
I can't seem to load this page on Edge at all.
Just attempts to load SAU.com.au/forums over and over then gives up saying the page can't be loaded or "there is a problem with this webpage"
Works fine in IE, Chrome, FF.
Dunno if reported yet but hey now it is!
I've changed you to the default theme, can you try again?
Looking good...
Group banners (SAU Victoria Member, etc ) seem to be missing, will they be making a return? I see Administrator is visible, but not the rest.
2 hours ago, BWRGTR said:
superb looking update, nice look
noticed pics missing in a few threads I looked at earlier this morning
Thanks!
Yeah images are being copied between directories atm (all 162GB of them) so will be available again soon.
9 minutes ago, Odium said:
Looking good...
Yep, they'll be back (they were briefly this morning but need a tweak)
Thanks!
Looking good...
Yep, the theme breaks it. Works fine in default theme, the dark theme is no good.
Funnilly enough its only the forums HOMEPAGE that breaks. Works fine if you are in a subfolder.
Hey Christian just having a few issues with the iPhone app, not all of my subscribed threads are showing in the subscribed section. There is also nothing showing in the notifications section.
Thanks for the hard work mate, it's much appreciated
Appreciate your hard work.
I cannot turn off the notifications for new content.
But more importantly I cannot turn on the emails when I get a message ...which I find handy:mellow:
Have a look at the notifications settings; http://www.sau.com.au/forums/notifications/options/
I believe anything in 'notifications list' will fire a browser notification.
You can also turn off browser notifications by clicking the icon to the left of the web address in the address bar.
New layout looks clean. I dig. Just one comment on the UX on the main page.
IMO, if you want to keep the forum going with fresh visitors, the main sau.com.au site *needs* a big shiny Forum button in the nav bar, just to the left of the Browse, Activity and Support buttons. It has to be the main call to action and at the moment, it's buried under browse and I had to hunt around for a few seconds to get here.
Users that don't already know that the forums exist are, in my opinion, extremely unlikely to find their way there.
Edited by Skepticism
  • Like 1
I totally agree, @Skepticism - I want to ditch the 'Browse' button entirely. We don't have enough sections to warrant a drop down menu.
Thanks for your feedback, its seriously appreciated!
Yeah, way better now.  A+ would be if you can get something similar on the mobile layout but I'm not sure of the best way (I'm more of a web dev than design/UX guy heh)
  • Like 1
Just now, barbados_26 said:
Anyone having any dramas seeing pics?
I can't see pictures in build threads that used to display fine before the update.
W10, Edge browser
Some images are still being moved (we've had some issues with the upgrade script).
Can you link me to one so I can ascertain if this is the same issue?
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
