E85 is not out of the question.  I would suggest that you can take the tinfoil hat off.  There are many people on these forums and others reporting that E85 sits just fine in a fuel tank without absorbing the Pacific Ocean.
And if you left the tinfoil hat on there are ways and means that you could get around any such problem.  Such as, put it away with a nearly empty tank, and put fresh fuel into it from a jerry can just before you use it.  Or any variation on the theme.
Let's face it....old petrol is worse than new petrol.  If you leave old petrol in a tank for 6 weeks it will change over that time.  If you ever find yourself leaving a car for a long period of time then the best thing is to leave it with as little fuel in it as possible and put new fuel in it immediately - well at least before giving it any curry.
I must be missing something here,
20 minutes ago, lcxu105 said:
It only gets use maybe once a month and can sit upto six weeks at  time and not move.
So e85 is out of the question.
I must be missing something here, there is a general statement then E85 gets ruled out.... how are these two things related?  Pretty much everyone I know who run E85 use them about that much and leave them for that kind of time period regularly as we don't get E85 at the pump, so it's usually a race car thing and the cars tend to sit with it.  The only issue so far with my mates ones have been one which had non-E85 compatible foam in the fuel tank which got dissolved and caused issues in the fuel system... lots of crap through everything, but easily avoided by making sure everything is E85 compatible.
Most race type fuels have down sides and things to be aware of, if you're going to be paranoid then use 98.
My car sat with half a tank of E85 whilst I had the motor and box out over four months. Starts and runs fine every time and the same fuel will still be in it when it leaves the garage in October, obviously I'll fill her up with fresh E but Iv never had a problem.
Another point- That fuel has been sitting in my tank since last December.
Plenty of people let it sit and never have issues.
Have used lots of old E85 that people have given away for sitting over 2-3 months. Oldest fuel I have used is easily over 1yr old and car ran fine, AFR was fine. This was giving the car a very hard time at Queensland raceway as well in 40deg heat
Doesn't matter.  Exactly what is going to happen anyway?  I won't type it all out again, but perhaps search for a couple of posts on here where I tiraded over the stupidity of thinking that gallons of water can get into your fuel tank through whatever air movement there is.
yes E85 is hygroscopic, ie will absorb moisture from the air, but at the same time, 98RON fuel has additives which are quite volatile and will "gas off" over time which will reduce the octane rating of 98 if left to sit.
A bit of absorbed water in E85 is less likely to affect it's octane rating, as it's the ethanol content that provides the high octane.
Normal 98 fuel left sitting could be closer to 95 octane by the time it's sucked into the engine - IMO a bigger risk on an engine highly tuned for fresh 98.
IMO the "sitting" time is not a good criteria for deciding E85 vs 98.
It's more about your horsepower requirements, availability of E85, ability to fill up on a long drive, carrying jerry cans of fuel etc
cheers
Mike
  • Like 1
31 minutes ago, lcxu105 said:
Ok than. I've heard that e85 turns into a jelly. Has anyone ever had this happen to them
Whoever told you that please go headbutt them. I have been running e85 for the past 4 years and left 40L in the tank while the car was off the road for 10 months and nothing bad has happened.
Maybe if your E85 absorbs enough moisture over time and you add a few packets of jelly to the fuel tank it will, but honestly it aint going to do shit.
Opened up my filters two weeks ago after sitting around from November with E85 in the tank. These fuel filters were cleaned in July/August last year. This is what came out. Was pretty yuck.
Whole fuel system went in the bin!
AD372875-F66A-4E59-B5B3-A148391C7DB2_zps
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
