34GeeTeeTee Posted December 20, 2017 Share Posted December 20, 2017 3 minutes ago, GTSBoy said: It needs to, otherwise there is zero point in making the manifold split pulse. I was going the single gate route but got talked out of it.... No regrets! 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7862945 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 20, 2017 Share Posted December 20, 2017 1 hour ago, GTSBoy said: It needs to, otherwise there is zero point in making the manifold split pulse. Won't quote names but I've seen a few from big brands appear to be split until both pulses are just going into 1x big 50 mm hole to the gate. Best I've seen from one brand was an open scroll manifold with a divided T3 flange welded on top lol 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7862951 Share on other sites More sharing options...
Deano 1 Posted December 20, 2017 Share Posted December 20, 2017 (edited) yeah 6 boost did the spilt for the gate. I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route. But at the end of the day, what for - why make it harder and most $$$ for the same result. Edited December 20, 2017 by Deano 1 2 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7862952 Share on other sites More sharing options...
Deano 1 Posted December 20, 2017 Share Posted December 20, 2017 1 minute ago, Deano 1 said: yeah 6 boost did the spilt for the gate. I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route. But at the end of the day, what for - why make it harder and most $$$ for the same result. Also the plate thats welded up the inside of the pipe from the mani to gate flange - Hangs out past the end of the pipe, once you weld the V band onto the end of the pipe - you than shape the "spilt plate" to suit the back of the waste gate, so its sealed up. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7862953 Share on other sites More sharing options...
sneakey pete Posted December 21, 2017 Share Posted December 21, 2017 This would be practically no different to the IWG housings, and i'd be pretty confident that it would be as good as twin gates. What stumps me is when people do have a split pulse manifold and the single gate isn't divided.. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863000 Share on other sites More sharing options...
sneakey pete Posted December 21, 2017 Share Posted December 21, 2017 Given r32-25t has posted a dyno of his -5's with vcam on the same dyno presumably as this i thought i'd put them together for interests stake. Of course if ramp rate was different etc might cause comparison issues but i figure this is better than most considering its same dyno and a short period of time apart. 4 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863007 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 21, 2017 Share Posted December 21, 2017 V-CAM and/or VCT is life. Anyone who says VCT or V-Cam as such is a waste of money OR for emissions OR for economy need to get their head out of their arse. 5 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863008 Share on other sites More sharing options...
sneakey pete Posted December 21, 2017 Share Posted December 21, 2017 For what its worth, going on boost curves etc, i'd expect my 2.8/9.5:1 8374 to be to the left of the -5 curve. But its hard to say if street feel would line up on a dyno etc. But yes if i had another spare 5000 i'd get vcam. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863010 Share on other sites More sharing options...
Mick_o Posted December 21, 2017 Share Posted December 21, 2017 (edited) Your car would belt the 5s just like every other back to back 5s vs 8374. Plus a run in tune would be low on timing I'd like to think which should fatten up the middle a bit more. V cam on your car would probably just induce surge. With the hi comp and .92 it wouldn't need any help getting it spooling! Piggies car would start surging on the dyno as low as 2800rpm. So even if it had v cam on it, you couldn’t move the intake cam anyways. Edited December 21, 2017 by Mick_o Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863011 Share on other sites More sharing options...
Ben C34 Posted December 21, 2017 Share Posted December 21, 2017 You could just advance the intake cam 20 degrees and deal with not ideal peak power cam setting and lumpy idle. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863012 Share on other sites More sharing options...
Mick_o Posted December 21, 2017 Share Posted December 21, 2017 Heres a better more fair comparison Pete. Heres Reapers old graph. Its 8374 1.05 with V cam and stock 2.6L as a comparison. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863015 Share on other sites More sharing options...
sneakey pete Posted December 21, 2017 Share Posted December 21, 2017 might plot that tomorrow arvo if i get a chance. Note the one i already plotted was -5's with vcam. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863016 Share on other sites More sharing options...
Piggaz Posted December 21, 2017 Author Share Posted December 21, 2017 So is that. FWIW, one drive in that and I was sold on this whole EFR “thing”. That setup there flogged my full effort 2.8/-5 . 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863017 Share on other sites More sharing options...
BakemonoRicer Posted December 21, 2017 Share Posted December 21, 2017 New EFR crew member checking in.... Manifold will be a 6boost w/ twin gates. Wastegates will be tial mv-s. Exhaust will be plumbed back via 3.5" downpipe The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads. ETA for completion is probably 6 months away. Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power. THEY ARE MAGIC fellas. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863018 Share on other sites More sharing options...
Mick_o Posted December 21, 2017 Share Posted December 21, 2017 21 minutes ago, sneakey pete said: might plot that tomorrow arvo if i get a chance. Note the one i already plotted was -5's with vcam. As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863019 Share on other sites More sharing options...
Mick_o Posted December 21, 2017 Share Posted December 21, 2017 1 hour ago, BakemonoRicer said: New EFR crew member checking in.... Manifold will be a 6boost w/ twin gates. Wastegates will be tial mv-s. Exhaust will be plumbed back via 3.5" downpipe The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads. ETA for completion is probably 6 months away. Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power. THEY ARE MAGIC fellas. Tell em the turbo son! Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863034 Share on other sites More sharing options...
r32-25t Posted December 21, 2017 Share Posted December 21, 2017 1 hour ago, Mick_o said: As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers. Because I was worried about the exact same thing I spoke to Jez about that and his dynos are within 3% of each other Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863042 Share on other sites More sharing options...
Mick_o Posted December 21, 2017 Share Posted December 21, 2017 (edited) Sweet thanks for clearing that up ? So lets call it "on par" you're at about 160kw at 4000.. The 8374 is at about 240kw at 4000?? 80kw through the middle with 60kw up top. Thats quite alot more power EVERYWHERE! Plus all those nice things EFR delivers that the dynosheet doesn't show... Edited December 21, 2017 by Mick_o Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863044 Share on other sites More sharing options...
r32-25t Posted December 21, 2017 Share Posted December 21, 2017 I’m happy with my car and thats all that matters 2 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863045 Share on other sites More sharing options...
sneakey pete Posted December 21, 2017 Share Posted December 21, 2017 I'm happy with mine also but coming from Tomei ARMS that wouldn't be a glowing endorsement did take it for a bit of a moutain squirt last week and its great, no 'to large to be fun' issues... and (once i get e85/boost) will have a shitload of power for whenever else i want it Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/60/#findComment-7863078 Share on other sites More sharing options...
