2 hours ago, Griffin said:
I've just gotten the 9174 running on rb26. Needs a tune. Alot better off boost but only makes  .5 bar at 4k rpm.
Will a tune fix the laziness much?
Ignore the boost gauge for a kick off mate. Get it dialled in and see when it boots you up the ass when you mash the loud pedal.  See how it responds to different throttle inputs etc
Just burying your foot on the accelerator and waiting for something to happen while watching your boost gauge isn't a good way to gauge how it's gunna drive. Especially if it's untuned.
10 hours ago, Griffin said:
I'm not too clued up on the tuning side of it. How much of an improvement do you expect after tuned properly?
Stand alone ebc.
There is no fixed rule, sorry.  Depends on how far off the current tune is for it etc - the actual boost threshold is unlikely to change much unless there is something mechanically (cam timing/wastegate/leaks) making it laggier than it should be.
What exhaust housing is it running?  What was the previous setup, or should I say - what tune it is running on if it's not tuned for this setup?    If it's completely untuned then I would take anything of how it drives with a grain of salt, and really not be driving it at all.
1.05 ts ewg. Previous turbo was 8370 wheel size Borg Warner journal bearing with internal wastegate that was too small to control boost.
Definitely a lot less restrictive now on the exhaust side.
Tuned on eflex with cam gears adjusted to suit. Has 264 greddy cams.
16 hours ago, HarrisRacing said:
These are my old pumpgas results on 8374 IWG with nothing more than changing cam settings (increased overlap).
where are they Pat , nothing to see ?
I've taken the efr off and am going to sell it . Went back to a smaller turbo and couldn't be happier.
I'll list it in for sale section if anyone is interested.
Did you actually get it tuned ?
What have you replaced it with ?
6 minutes ago, Griffin said:
No , pulled the plug before it became too used and worthless.
Upgraded to a turbo off a tractor.
You mean downgraded to something better matched to what you wanted?
The 9174 was laggier than the old Airwerks ?
Yes correct. Tune would help. Ive got a forged 3025 neo and r33 gtst.ill put it on that if I don't find a buyer. Any help selling would be greatly appreciated. The one I put on is slightly similar to what came off but with t4 rear and better twin scroll manifold / external gate setup.
So its like a Borg Warner S300SX 8375 or something - 60mm turbo?
I'll mention it to Kiwis who may want a 9174, you have the 1.05 hot side?
Yes mate to both questions.
What I'm using now is basically an 8370. It starts moving just after 2000 rpm.
It would be great to find a buyer thanks.
Can't promise anything but will mention it.
Where do you get an 8370!?  Never heard of such a combo
That's what the wheels measure up at. Extended tip compressor too. The first one I used on this car was off an eimco ed10. Screenshot_20180419-165043.thumb.png.5d86742b662ec24ce8cd2f0e13885fc9.png
That was '8374' size with cut down water cooled turbine housing. The one I just took off was '8370' with twin scroll t3 turbine housing and internal wastegate which the ports were way too small and not able to control boost.
The new one has the same size wheels in a t4 twin scroll housing but I've made it external waste gate. It works great.
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
