9 hours ago, Roy said:
They binned the EFRs for Precision! At least they are man enough to run twins. Give them another few years and they will finally see the light and rock Trust turbos
Lol!  That would be pretty grand, and to be fair - they are using pretty advanced lag reduction techniques so they can probably run a relatively potato turbo and it shouldn't be too much of an issue.   Pretty funny seeing the now old/iconic Precision "bullet" antisurge ports on something this fancy.
I have to say, if that transmission works the way he is expecting it to. It will be a game changer. The speed and driveability if a DCT with closer to manual weights. Not to mention packaging advantages.
Edit: aww hell, I screwed up the quoting somehow. I was referring to the Koenigsegg video
Edited by Silverhks
it looks like they may be evaluating options or doing mockup/fitment. but surely dual 7670s aren't going to make the quoted 1600hp so maybe not. and its footage of two different engines, as the Agera RS and one:1 engines definately had precision snails on them.
here are a couple of screen grabs for the Jesko video...
EFR is on one side of the motor, precision is on the other? (ps that finish on the investment cast efr turbine housing is NICE.. like the early ones before they changed to a cheaper sand casting method)
Edited by burn4005
Those turbos look smaller than EFR7670 as well, probably 6758s or 7163s in that frame - definitely not 1600hp worthy haha.    Guess they figured they can use the bigger Precision turbos and use other tech to try and spool them faster was a nicer setup than making less power with naturally more responsive turbos.  Simplicity is not the theme of this car haha
multi million dollar car and using shonky turbo's with china sourced turbine wheels, compressor covers, and other misc parts....  gold. Obviously does not give a f**k about compressor maps or engineering of those items ?
  • Haha 1
Does anyone have any idea how a 8474 would compare to a 9180?  The 8474's compressor flows the same 95lb/min as the 9180, but the catch is, will it ever flow reach the potential that you see on paper in reality with a smaller turbine than the 9180?
I've been keeping an eye out and know of about 3 cars (two RBs, one 13B) which are going to be running them at some point but no idea on ETA.   The only EFR black series result I know of other than Eric's EVO is an EFR9274 on a 2JZ drift car which made around 1000whp.
^ way too small for a 13B engine IF used for maximum output.
Forget the dyno sheets, lets see if anyone else puts up actual performance (in a 3rd gen RX7), that is if they don't detonate and spray oil on the rear tires like the majority seem to specialize in ?
Yeah, the owner would be the first to say that it's not going to do the turbo justice - he won't be winding it up, engine is relatively stock spec.
On 3/12/2019 at 7:31 PM, minesskyline said:
@Full-Race Geoff or anybody really: Are there any EFR based (single) turbos that can achieve 1100+ hp (to the wheels)? Running a 26/30 (3.2l) (the thread for this is incredibly dry) for reference.
Hard to say what a 9280 1.45 will be capable of at full tilt?  I dont know yet.  I agree with burn4005 that twin 7163 would be the best way to acheive the 4-digit power levels.  Garrett G25-660 is also a consideration.
If you really wanted to stay single turbo, the G42-1450 may prove to be a good way to do that.  still a bit early to know on that turbo as well
:4_joy:
edit - another evo on 8474 is ken thwaits from showtime motorsports in the usa.  he switched to 8474 recently, and after the first event he said its insane, 4 wheel spin has required some changes to their setup and tune
Edited by Full-Race Geoff
He said 674whp which is decent power but not anything which makes it seem like it is running an upgrade from an EFR8374 :/
Edited by Nismo 3.2ish
Wrong info
Puts on EFR and makes excuses? FYI 100% Stock motor we ran on EFR9180 at 2850mB easily, when took engine out on tear down it was perfect inside, even on full knock limit running ;) then again it runs a proper ECU ;)
As the most respected/qualified Internet knowledge & on line learning vehicle modifiers in the world said and I quote:
"If I was too like buy a hot water balloon and I don't fly it, like whats the point"
Edited by RICE RACING
Who made any excuses about anything?   You are the only one acting like there is an issue :P
Let's see when the kunts show the performance  ;)
Everyone prefaces 50 different excuses as to why it wont do XYZ, typical of the times we live in now in Generation GAY.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
