The new genV turbosmart twin port is probably the way to go. It has a better lower seal and a universal joint to the wastegate actuator arm. I wasn't very impressed with the first two versions (non twin port and the first twin port) but the latest one should be good. Use a low pressure spring or it'll be too sensitive.
The e-iwg cost wasn't too bad (less than the turbosmart actually), but yes, you will have to adapt it to fit and have an ecu that can drive it.
Position data is nice.
Edited by taijohnsen
I thought the supra parts were already a few hundred bucks alone?
Do you have a list of items that are needed for the e-iwg?
Can't seem to find anything useful with google.
The genV twin port is $500ish AUD and the std one is $300ish AUD. I managed to get the e-iwg landed from USA for $350 AUD.
A bit of 3D printing and a carton of beer sorted the rest.
More pics in my thread http://soarercentral.com/sc-forum/messages/263854/354587.html
Hey Tai!
Just finished reading your thread on soarercentral from start to finish.
Very nice build and a lot of cool selfmade stuff in there.
The electronic wastegate actuator is awesome, but setting it up + 3d printing parts for it is way out of my league.
Another question though:
With your latest dyno session, whats the turbo shaft speed that your speed sensor is reading at max?
Thanks and have a nice weekend!
Now that my build is finished after 2 long years being off the road I can finally contribute to this thread with my EFR results.
EFR 8374 1.05 A/R
Racepace built RB28
9:5:1 compression ratio spool pistons
Nitto I beam rods
Spool billit 2.8 stroker crankshaft
PRP engine brace
HKS step 2 valve springs
6 boost manifold
Turbosmart 60mm wastegate
Nitto oil pump
Racepace custom 3.5” dump pipe & cat
Tomei extreme titanium cat back
Plazmaman 100mm intercooler
PRP trigger kit
PRP R35 coil kit
Tomei cam gears
Haltech elite 2500
Bosch 1650cc injectors with flex fuel
Nismo front LSD
Racepace transfer case upgrade
Plus many more mods
Made 504.9kw 25psi on E85
Couldn’t be anymore happier with the result and build. Turbo feels awesome and love the responsiveness.
  • Like 3
1 hour ago, burn4005 said:
Roller speed axis should be made illegal.
What gearbox, diff ratios, rims and tyres?
I agree..    based on my own car that would be boost in at around 4100rpm I think.
But why they don't use RPM is beyond me.
Gearbox stock, diff ratio stock, rims volk GT-C 19x10.5 pirelli p zero 275 and cams are stock atm because mine are on back order. Have a set of mines super shore pro camshafts just waiting till they arrive and will get them installed. Tune has been wound back to 460kw @ 23psi while the engine is being ran in and till the cams arrive.
On 1/9/2021 at 8:44 AM, MotHot said:
Hey Tai!
Thanks MotHot,
It has been a long build, but I have enjoyed the journey for the most part :)
Sorry for the delayed response, but the tuner took a while to get back to me with the logs.
The internal power calcs of the EMtron say 350kw engine, this run was 350rwkw @ the wheels (roller)
  • Like 1
  • 3 weeks later...
Because who gives a shit about rpm.. road speed is where it counts!!! :)
Lol, all you stroker big block RB boys would realise your better served by laggy RB20s that rev to 10,000rpm with 4.6 diff :)
  • Haha 3
  • Confused 1
  • 4 weeks later...
Hello, could you guys help me choose between 8374 and 8474, both with 1.05 housings, for 2jz ge non vvti engine. Quick specs are 9.5CR, BC264 cams, sligthly ported head. The target is 650 to around 700whp with best spool and response and 7500 to maximum 7800rpm limit. Is the 8374 be enough or 8474 will be needed for those goals? Fuel will be E100. Thank you in advance!
Matchbot will tell you there is no way an 8374 should be on a 3.0L RB.
That said, I ran mine happily for some years at sub 120krpm making 650-700hp at hubs and spinning to 7000-7500rpm on both 3.0 and now Nitto 3.2.  Intake temps were ok - but it didn't want to make any more power.  It has finally let go just two weekends ago.    We had recently added launch control which may or may not have contributed (or at least shortened its life).     Everything on Matchbot says its should be overspeeding, but I've got logs to show it wasn't (unless there is an issue with what/how we are reading) - so I am not sure how this correlates to Matchbot..  perhaps the default VE figures are different enough to affect it?
I've also run an 8474 on same engine (3.2L, both 1.05 rear) and it definitely feels laggier than the 8374.  On a dyno plot its only about 200rpm later coming on, but in practice, on a rally sprint coming off 2nd gear corners, you notice the difference.  Also between gear transient response is dulled a bit.
8474 makes about 50hp at the hubs more on same boost (750hp at 23-26psi) , temps post turbo (pre intercooler) are only 10 degree cooler. And post cooler can't see a difference.  Definitely when in the mid-range revs and up you feel the extra legs it has.
So!  for me, on a 3.0-3.2L  I'd be going 8474 and altering gearing to suit what you're doing,  and keep it a bit further up the rev range.
  • Like 1
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
