  • 5 months later...
So, I've been a busy boy in between running a business, being an adult and shit like that.
so here goes!
since I last left off, I had gotten my hands on a wrecked shell and scavenged the parts I needed from it.
following this, we had the chassis rail pulled straight (with no resistance) and had the rest repaired.
thats when the fun started.
the car has been hit on that side before, hard.
this made unpicking a nightmare! But we got it done, it isn't pretty, but it's done.
Painted the bay bay this week end, and now starts the assembly stage! We're getting closeeeeeeee
  • Like 5
  • 3 months later...
Update:
progress has been slow, but we’re getting there
im still slowly accumulating parts, managed to pick up a really tidy steering wheel and original wing and not pay drug money, but more importantly, the car is now sitting at my panel beaters, waiting for the boys to have a crack at some body repairs and paint.
i can’t seem to find out which is the correct shade for the car, but it’s been smashed, repaired etc so f**k it. I’m going for the nicest TH1 there is, standard base with a lighter, greener flop.
same delicious TH1, with very very slight aqua tones at different angles
We should start moving quickly from here, I hope.
  • Like 2
2 hours ago, Robzilla32 said:
How do people find stuff like this?
Presumably to get that price you had to swallow as well?
I still don’t know, ebay.. I saw them and just put my maximum bids in, someone had a go at the wing but nobody bothered with the wheel..
also picked up an R34 GTR intercooler, couldn’t be bothered paint stripping the original one lol
  • 1 month later...
Long time no post, you’re all probably used to that by now.
the car is now at the panel shop.
it seems that one of the previous owners had tried to roll the guards and warped the steel above the arch, so I went ahead and gave them a proper roll.
the boys at the panel shop will fix this.
We’re going to begin repairing, rubbing etc this week end and hopefully have it painted in a few weeks.
i guess the great part of a close friend being your panel beater is that he wants it perfect.
so he made me rub the entire bay again.....?
  • Like 1
Had all of the intake stuff apart and cleaned up.
gave it a coat of KL0 and clear, came up looking awesome.
also, found some crusty rust and bad repairs.
typical area around the tail lights, but the previous owner tried to pack it out with sikaflex...
  • 4 weeks later...
  • 3 months later...
Hello friends, long time no post.
I guess things really do take time when they’re done properly.
the car has had the required rust repairs and is now ready for high fill.
i know the bog looks bad but it’s only a skim of fine filler. Only so much the lads could do without replacing the quarter panels etc.
the car has had a bad quarter change in the past, with both panels lined up and filled with weld. I had the tedious task of cleaning the canyon and getting it prepped for brass, followed by some of weirdest filler I’ve ever seen- that fibreglass looking stuff is actually aluminium infused filler that is being used on bmws now!
take note of the rust hole on the pilar, it looks like this is a problem area on a few GTRs due to the location of the factory window trim clips holding dirt and moisture. This let water trickle down into the boot channel, and then down the beaver.
bought a set of rays gramlight 56crs in 18x10.5+12, yes, they’ll fit. I don’t care how it’ll drive, it’ll look shit hot haha.
pic dump
  • Like 4
Repairs are DONE!
Body is in high fill!
engine bay in boot is looking f**king silky.
spent the last couple of days helping out at the panel shop and doing a little more on the hoist ;)
  • Like 1
  • 1 month later...
  • 2 months later...
finally got some rubber on the tyres, they fit good.
body is painted, parts next and then it’s on it’s way to my warehouse to be finished off.
paint came out like glass ?
  • Like 4
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
