Weird how the battery has been ok, till when I decide to go grocery shopping.
Lucky enough bumped into my mate, also grocery shopping lol. Clearly the ladies in both our families aren't trained well.
  • Like 2
In pursuit of a quiet gentleman's car, ive decided to add more mufflers :)
Proposed new set up will have a cat still, and the external plumbed back after the 100 cell cat.
Both exhaust and gate will merge into a small cylindrical muffler, then into an oval muffler and then a large fk off muffler. All 3.5", hopefully I can hear all the squeaks in the car and all the noise from the rose joint arms lol.
LHS = Hi-Tec (extremely heavy, stainless but ends are sprayed black)
RHS = SMB last of them forever I think. They've shut shop as the owner is ill :(
All 3.5"
  • Like 1
All 3.5"
I decided on magnaflow so went down to a place near by to get them, they actually suggested to me to use smb but it was christmas time and they had already closed for the break.
I went home thinking smb and ordered some other mufflers for it online lol funny how that seems to happen.....
48 minutes ago, Jordy32 said:
Oh that's a nice seat!
May I ask the price? I'm thinking of selling my brix 1.5 for a fixed back.
Thanks man!
Was about $1.6k with rails from Jesse Streeter, however we ordered a bunch of other shit too.
24 minutes ago, timmy_89 said:
when did you turn so soft :4_joy::4_joy:
shu habibi, wot do you meannnnnnnnnn? lol
Still, if you came to my house tonight with a 335i, 4 door, N55 motor, under 80 000 km, clean (not perfect) M Sports version, well maintained and a slab of beer in the back I would straight swap you the R33 and all my tools, minus the tool chest itself.
  • Like 1
Pfft.... no chest no deal :4_joy:
you no deal :)
Tool chest was a birthday gift from the missus, that stays.. everything else inside comes with the car LOL
  • Haha 1
On 2/6/2018 at 12:22 PM, AngryRB said:
?.. where was the dose??
Took @Piggaz for a spin yesterday, he confirmed dose was there and sounded gay LOL.. also confirmed single turbos are better than twins LOL
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
