3 hours ago, Dose Pipe Sutututu said:
I am back from 1 month of no SAU and car shit
Adaptronic is coming out, and is now for sales. $800 for SAU members $850 for Facebook or Scumtree or eScum
Ahh how good is it to have a month off.... (congrats by the way kent!!)
Why the move to a Halaltech?
2 hours ago, dr phil said:
Not going an Adaptronic modular, or an EMU Black?
As much as I support and recommend Adaptronic, a Haltech is so much faster to tune and get going when compared to an Adaptronic. The ECU Master range does look promising but never used it before, so means will need to spend time to acquaint myself with it.
Haha thanks man, part of the club now :)
I've outgrown the 440D Select and also over the idiosyncrasies involved with their software. Every time I set up the crank prime value it reverts back to a negative value approximately 4 to 6 starts, so these days I end up carrying the laptop with me to start the car lol.
Over night parts from Kudos Motorsports.
OEM wheel bearings all round, road safe ball joints all round and new washer motors because I like a clean windscreen lol.
34464030_240876389797466_2688695212863127552_n.thumb.jpg.d7357ee9411336a3571b50675b85ff73.jpg
So.... Had a few beers at work and accidentally ordered a few things.
AI SPR400, 1x DW200 lift pump, 1x more Wallahbro 460..
Hopefully no more fuelling issues ?
2 hours ago, Dose Pipe Sutututu said:
Do youse English?
Wallah DW200 is lift, twin 460s feed!
Mashallah
Who was english?
Did you order a stroker or you didnt hvae that many beers?
23 minutes ago, WantGTR said:
Who was english?
I'm not that dumb brah :)
Watch my little 2.5L motor thrash 2.6L fags with twins
  • Like 2
Hopefully no more fuelling issues [emoji28]
It is good to know that others do this. My Mrs is trying to convince me that late night / early morning orders from Plazmaman, rhd, amayama, etc. are a bad idea
Some parts to help my motor spin backwards and forget tunes ?
Special shout out to Alanah and James at Game On Motorsports. Twisted my arm and ended up with an Elite 2500 and a 4 bar MAP sensor instead of me only just getting an Elite 2000 and using the onboard 3 bar MAP sensor lol.
Currently car is at thr mechanic getting new wheel bearings and ball joints installed because I cbf doing it myself (although I have all the tools and access to my mate's press)
  • Like 3
26 minutes ago, hy_rpm said:
Planning on running more than 3bar boost?
Glad someone did the maths. I was going to get to it tomorrow if I had time.
  • Like 1
You mean 2 bar of positive pressure, 3bar sensor needs to also read vacuum too :)
Also if you don't use the onboard MAP sensor you can use that to adjust the tune for atmospheric pressure changes
Lastly I prefer the MAP sensor as close to the plenum as possible.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
