Nice yellow 34 on carsales, expensive as hell (34k), but looks real nice.
After dropping a few k on it, it would be fun, maybe.
I wonder if I can find 40k in the lounge?
Dafaq? 34k? Better have a Samsonas and a Maatouks ulleh build.
I estimate full boost by 4.5k, a responsive 375 killerwasps with a big fat flat 685 pillowcase curve, or.....https://www.sau.com.au/forums/forum/12-for-sale-private-car-parts-and-accessories/
Disclaimer: I've got man flu so all guesstimates are based off the Codral night time I'm washing down with Jack Daniels.
 I'm washing down with with Jack Daniels.
Washing down.
What was the question
  • Haha 1
2 hours ago, ActionDan said:
Dyno for sure
Nobody would buy that.
But why would I tow it there? Why couldn't I street tune it, get it driving well then drive it to the dyno tune it then drive it home? ?
1 hour ago, admS15 said:
Or #Barratheworld
http://www.my105.com/ListingDetails/p/1/id/21242
Best pry for you, cheap cheap
Man they need to redo that site, it's not even responsive to browser width!
But good price 7k!
That's what I get for not following the link. I assumed the link was just for an engine.
I guess it does fit. Makes you wonder why he's trying to sell it that close to completion.
Over it probably, I've listed my shit box up for sale many times but no-one wants a shit box.
Especially one that's not built by any big workshop nor running 10k ECU packages with sensors that no one needs or understands
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
