1 hour ago, iruvyouskyrine said:
What wheels are those? DNA origin?
Rota Grid inspired wheels made by Rays Engineering. They're Gram Lights 57D in 18x9.5 +22.
Btw I'm trying to convince Benny to do a DBW, DBW Pedal, and wire in patch loom for RBs with connectors terminated. He said he would think about it, I said you could whor3 it out on SAU very easily.
I would certainly get one, all the hard work done just need to patch in 6 pins and done!
They aren't 57D as they are a 7 spoke design not 6, also looks very different.
Yeah i have been in his ear about that sort of stuff however Powertune have got that market pretty stitched up tbh. Most of it is for GT-R's tho, and gtst people only spend $ but GT-R owners are happy to spend $$$$$$$$$$$$$$$$$$$$$$$$$$$$
  • Haha 2
Lol... No idea man, I better go check, I know they're Gram Lights haha.
Powertune kit is so Motec centric though, gah. I'll end up making my own kit, just cbf.
Just need a z33 pedal, 74mm bosch throttle body, relay with fuse and half a dozen wires. Depending how insta spec you want the wiring it's a few hours.
shia labeouf GIF
  • Like 2
  • Haha 2
Just go get a roll of red 3mm from supercheap, electrical tape and solder the joints to the z33 pedal loom. Maybe be fancy and use some dual wall heatshrink ?
We could nearly get a "group" buy, I've got a trade account with TAARKS and we could get someone like @iruvyouskyrine to make all the patch/aux looms for the DBW and pedal.
Then all we would need to do is just pin in 6x wires into our ECU of choice.
If done correctly and supported its fine but will definitely lose momentgram followers.
I really should finish my car with DBW so can have a proper go at a few of the features.
Yeah making the wiring is easy, organizing the group buy and actually getting people to pay is usually the hard part ?
  • Like 1
  • Haha 1
Haha very true, let's work something out.
I can supply all the DBW units, and pedals. I'll message TAARKS and see if I can get better than trade pricing for 5 of each.
  • Like 1
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
