i recently threw out the 45 degree frame i had for my old 12 panel system you could of had :(
Soume guy gave me $200 buck for it , was supposed to come pick it up about 2 years ago and never did lol
so it went in the metal recycling bin.
  • Sad 1
On 09/07/2021 at 1:21 PM, ActionDan said:
Hmm would I get much for some aluminium RHS???
nar i called the local metal recycler and they said unless i have like 50 plus kg they were not interested.
so put it on facebook market place lol
  • Like 1
On 09/07/2021 at 12:44 PM, ActionDan said:
You can DIY a tilt adjustment easily enough.
I have a big set of adjustable aluminium legs sitting in my shed doing nothing, kept them for the materials alone.
I didn't need them as my roof pitch is bang on for my locale.
Also these babies arrived.
No description available.
party time, I want to see your graphs lol
On 09/07/2021 at 9:30 PM, Ben C34 said:
Area under the curve f**kers
Not in our experience. In our current place we need to optimise for morning sun in winter (heater) and afternoon (AC) in summer. Pretty much all year round in the middle of the day to mid afternoon the battery is full and we are getting 5c to export which is a waste of time
  • Like 1
Yep batteries change desired usage and output patterns a bit.
My china inverter (MPP) on the off grid has stopped giving me output from both MPPTs, only showing one currently (global issue with them it seems on the cloud platform) so charts aren't as helpful as it only shows 1 array.
I can get the days total output off the inverter though so I expect it to go from like 6kwh on a nice sunny day to maybe 8-9 hopefully.
The on grid system is only giving me like 7-8 on a good day before the shade kills it. I hope to get another couple kWh from that after I remove the tree.
All my stuff is mostly north - west facing so it all suffers in winter here being up on the hill where the sun is gone very early.
Summer for the on grid is like 20-24 before shade kills it, ok for a 7-8yr old system,l I think.
Off grid will do better but I haven't had it through summer yet.
Edited by ActionDan
  • Like 1
Started fitting optimisers, 3 down, 15 to go. Fiddly job to do neatly and keep cables up and out of the way/weather/off roof etc. Would be easier if being done before panels were fitting.
Connected 1 and turned everything back on to make sure it worked first.
Nothing blew up, didn't die.
Stay tuned.
  • Like 2
Stay tuned.
Should be interesting to see the yield increase!
My mate recently got a solar system also installed at his place, albeit on two different roof sections with different pitches. His panels however do face North. You would think because of this he would yield less compared to a North facing house with a flat roof (all panels get East/West sun all day), but everyday he is consistently getting 5kWh more than I am.  Geographically we are about 10km apart and his house is west facing.
We both have 17x 390W JA Solar panels, but he is running a Fronius 5kW inverter where as I'm running a GoodWe one.
See how we go, I just put 4 more in, leaving 2 to go on that array and the 9 still to go on the other array.
Given my shading I am expecting a gain but do not have good graphical data to compare only my anecdotal monitoring.
That said, the panels will be happier as the bypass diodes won't be getting worked so hard given the shading I get in winter months.
  • Like 1
Went through my old Go Pro to delete shit and found this gem!
Terrible driving, street tyres, Bilstein/King Spring suspension setup and dose :D
  • Like 7
On 05/08/2021 at 11:43 AM, Jasoncauser said:
what tyres where you running then? a little loose onto the main straight :)
If I recall they were just Nitto NT05 tyres all round - nothing flash. It did have ~320kW LOL
  • Haha 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
