On 8/11/2021 at 9:33 AM, Jasoncauser said:
I wish Wakefield and eastern creek were in GTS lol
Bathurst is the only Aussie track int he game
Can get them in Assetta Corsa (via download) on the PC (not console)
I think it was in grid on PS4 they had Sydney Motorsport park
This nearly seems affordable (sorry about the small thumbnail, @PranK still hasn't fixed the image width size)
https://dofreality.com/
On 11/08/2021 at 2:31 PM, Jasoncauser said:
you know thats only the base?
no seat, wheel, pedals etc
Yeah I know - full kit will still be less than me blowing up another motor LOL
  • Like 2
  • Haha 2
  • 3 weeks later...
Making myself a temporary DBW patch harness.
It's nothing pro or club level, just amateur level stuff. Pulled apart Narva 7 core trailer wire and bundled up what I needed.
Still figuring out where I want certain sensors and looms run.
Also, repurposing the old AFM and O2 wiring into an EMAP. For some reason I was under the assumption the power for the AFM is sensor +5V, clearly it isn't so have repinned the narrowband O2 input as a +5V feed for the pressure sensor.
  • Like 1
And done, finished after my son went to bed.
I'm using a V35 Skyline pedal, I did have Z33 350Z one but I didn't like the alloy pedal and wanted a stock looking one.
  • Like 4
Look at you go makin stuff!  Good job! I might go rob the neighbours Triton to war and make my own! 😂
The Asian in me didn't want to pay some auto electrician to make a temporary harness 😂
Future state, will plan out where I want everything to be, and how the cables will be routed and then will pay someone to do the full loom.
FWIW, Narva 7 core trailer wire comes with slightly smaller cable (2.5mm diameter) compared to Narva 5 core trailer wire.
A bit overkill for sensors and a DBW motor still.
  • Like 1
overkill is pretty much always better than under doing it when it comes to wiring!  Are you running the pedal wiring back across under the dash to the ECU and then out through the firewall or are you running some of it straight through the firewall at the pedal to the DBW motor?
  • Like 1
Wiring is going across the firewall (cabin side), then the TB wiring will come out the grommet driver side and then out through that hole where the brake master cylinder is.
I thought about using the throttle cable hole but the DBW TB plug wont fit (unless I de-pin it).
Following Haltech's instructions I ran all sensor power from the pedal & TB back to the ECU side. I've seen some harnesses where sensor power goes from ECU to pedal, then pedal to the TB. I can't see a real issue with that - however better just stick to what Haltech documents to avoid any issues.
Oh hai, I'm sure someone will ask, "why didn't you get I-Beam connecting rods?"
Simply put it, I'm not after 746kW at the wheels. There's 0 desire for it, so these Manly H-Beam connecting rods are perfect for my requirements. Not to mention they came out unscathed from cracking a block in my old motor.
Pretty excited, should be up and running soon enough 😁
  • Like 5
On 01/09/2021 at 7:52 AM, ActionDan said:
So is it not cool if I bought I Beam?
To be fair I have 2 less cylinders to work with so need to work them harder :D
haha yes! simplified calculations puts each of your rods at 125kW, where as for me 83kW :)
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
