On 15/08/2022 at 2:13 PM, Dose Pipe Sutututu said:
Kind of can, I have a feeling there will be max level of anxiety on the day lol...
I have a Garmin VIRB which tracks a few data points such as laptime, speed, Gs, etc.
yeah ok cool
Harry's laptimer is pretty cheap for what it is
https://www.gps-laptimer.de/products
If you just want video with overlay the Petrolhead version is like $20
I got the full Grand Prix version at like $30, just more features i may or may not use haha
  • Like 1
See how I go, if I start to get back into circuit racing like before I might just buy this:
https://www.garmin.com/en-AU/p/690726
On 15/08/2022 at 2:19 PM, ActionDan said:
Race Chrono (paid) gets my vote, controls the GoPro as a rempote and does overlays on the video for you.
Nice, I havent used Race Chrono.
Harry's does multi cam too, with video in video. But havent played with the 2nd camera options yet. I do have a gopro8 so may be something ill try down the track.
Watching these replays has really helps improve my driving lines and lap times.
Damn!! Maybe worth while if you were a pro driver
Overkill for us weekend warriors haha
I know someone who has one and its amazing but he is funded by bank of dad and is serious about getting to supercars.
Takes video of fastest parts and makes a perfect lap, will tell you when to brake too.
  • Like 1
"Takes video of fastest parts and makes a perfect lap, will tell you when to brake too."
thats a pretty cool feature.
Let's just say that private track day, I might have one of those strapped in the car for testing 😎
I'll reveal a bit more after the day.
  • Like 2
Awesome, be good to see how you go.
On 15/8/2022 at 12:47 PM, Dose Pipe Sutututu said:
Lunch time tingz
Added stickers 😅
Now I need to see if R33 and C34 have the same ashtray as that fits well
Doooo it, you need it lol.
Just a note, you need to clearance the trim to clear the Deutsch connector but nothing a 22mm hole saw bit can't fix.
So does trackaddict, though I would suspect RaceChrono paid (which I also have) does well, but trackaddict also overlays OBD2 data from the car if you want that too. Maybe Racechrono does. Point being, get it setup right and all you have to do is hit 'record' and your video and telemetry gets synced and life is good.
Will see how well this all works for me on sept 2 :P
  • Like 3
Latched Launch Control. G4+ and G4x have this feature. Just push and hold the button and the engine won’t rev passed that point.
I have it installed for roll racing, grab the button at 4500rpm+ and it will make boost then release for warp speed
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
