niZmO_Man Posted October 26, 2022 Share Posted October 26, 2022 Don't worry, in 10 years' time you'll be glad you kept your $150k R33 3 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971806 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 27, 2022 Author Share Posted October 27, 2022 On 26/10/2022 at 7:12 PM, niZmO_Man said: Don't worry, in 10 years' time you'll be glad you kept your $150k R33 Straight swap for gravitating BMW Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971851 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 27, 2022 Author Share Posted October 27, 2022 Won Powerball, just enough for another shitbox GTS-t.ย ย Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971856 Share on other sites More sharing options...
Jasoncauser Posted October 27, 2022 Share Posted October 27, 2022 lol me too 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971860 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 28, 2022 Author Share Posted October 28, 2022 WTB Skylines, healthy budget. Can spend up to $10.55 per car. 3 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971869 Share on other sites More sharing options...
r32-25t Posted October 28, 2022 Share Posted October 28, 2022 I was in a group and we won $44 split 8 ways lol 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971877 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 29, 2022 Author Share Posted October 29, 2022 17 hours ago, r32-25t said: I was in a group and we won $44 split 8 ways lol More than enough for a Silvia LOL.. 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971898 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 31, 2022 Author Share Posted October 31, 2022 ๐ ย Yep, truth, struth, farken. 5 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7971953 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 4, 2022 Author Share Posted November 4, 2022 Tonight's activities, trying to fix the ABS. New relay in and nope, still have an ABS light. Will check fuses next, followed by sensors then ABS computer. If all else fails, will retrofit a new ABS system (yeah nah, jk). ย Then made the car appear a bit more legal(?) Lol... Factory 18s officer. ย 5 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972089 Share on other sites More sharing options...
Murray_Calavera Posted November 4, 2022 Share Posted November 4, 2022 This would look fantastic in there https://www.peracing.com.au/products/bosch-motorsport-abs-m5-kit-clubsport Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972093 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 5, 2022 Author Share Posted November 5, 2022 2 hours ago, Murray_Calavera said: This would look fantastic in there https://www.peracing.com.au/products/bosch-motorsport-abs-m5-kit-clubsport I think so too ๐ Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972098 Share on other sites More sharing options...
No Crust Racing Posted November 6, 2022 Share Posted November 6, 2022 Popped in to see if there was an M3 yet, left disappointed.ย ย 4 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972145 Share on other sites More sharing options...
BK Posted November 7, 2022 Share Posted November 7, 2022 On 17/10/2022 at 9:55 AM, BK said: You use a link right ? The link you can reassign the cam signal cable to actually be the crank reference signal. On an Elite you can't as it is a fixed pin on the ECU, so they were sending them out preconfigured for link wiring on cas wiring pins 1 and 3. Yes a reluctor generates its own voltage. Can't believe Haltech told you to supply it 5v ! From what I can see the neg reluctor side needs to be pinned to ground and the pos side signal output pinned to the Elite TRIGGER +, so on a cas loom that would be the 2 outside pins 1 and 4. The way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do. Got my NZ wiring cam trigger today and got it working on the white 32. FYI what I posted above is correct to work on the Elite. Pin the reluctor to the 2 outside pins using signal ground and crank trigger +, no ecu repining required. 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972179 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 7, 2022 Author Share Posted November 7, 2022 3 minutes ago, BK said: Got my NZ wiring cam trigger today and got it working on the white 32. FYI what I posted above is correct to work on the Elite. Pin the reluctor to the 2 outside pins using signal ground and crank trigger + Nice, you'll notice you'll have less trigger count errors at higher RPM compared to the OEM Nissan CAS. I updated my post on the Kebabtech forums too. Funnily enough someone also PMed me on the Kebabtech forums asking for help regarding the NZ Wiring Cam trigger too. Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972181 Share on other sites More sharing options...
BK Posted November 7, 2022 Share Posted November 7, 2022 I still would much prefer the proper Ross crank trigger setup I have on the blue 32 with DC powered hall effect sensors though - can't beat measuring the crank position from the actual crankshaft. I sort of winged it with the trigger arming voltages, something you don't have to worry about with the hall effect sensors. Might have to have a look back at your voltage table for comparison, but I gotta say so far so good. The timing light is not jittery like a cas and is rock solid, so without going proper crank trigger these definitely seem like the next best thing especially for the price. 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972185 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 7, 2022 Author Share Posted November 7, 2022 Of course, nothing beats a crank trigger. However this is decent for low powered RBs (sub 500kW is considered low power these days lololol).ย I might look into a stronger timing belt to avoid belt stretch. Currently just has an OEM belt in there. Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972192 Share on other sites More sharing options...
BK Posted November 7, 2022 Share Posted November 7, 2022 2 hours ago, Dose Pipe Sutututu said: Of course, nothing beats a crank trigger. However this is decent for low powered RBs (sub 500kW is considered low power these days lololol).ย I might look into a stronger timing belt to avoid belt stretch. Currently just has an OEM belt in there. I had Gates racing in both 32s but as everyone knows they are a pretty noisy belt. Still running gates in the white 32 but changed to a Nismo in the blue 32, sounds like oem in comparison. In my 33 I'm using a Power enterprise belt which also sounds like oem. The issue with gates belts seems to be the nylon glass chord construction making them very stiff, whereas the Nismo, Power enterprise, HKS etc. have a high kevlar count in their construction making them very flexible and therefore sound less whirry. 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972197 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 8, 2022 Author Share Posted November 8, 2022 Without going into research, which belt would you think would stretch the least? Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972200 Share on other sites More sharing options...
BK Posted November 8, 2022 Share Posted November 8, 2022 Maybe Gates, but I am judging that purely based off of their stiffness. Maybe I am talking out of my arse too because Nismo and the like would not use kevlar for no reason, as it has a higher tensile strength than steel. I think I'll be stuck in the Nismo or Power enterprise belt camp. Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972201 Share on other sites More sharing options...
Duncan Posted November 8, 2022 Share Posted November 8, 2022 I'm surprised you can hear a properly tensioned timing belt over the fan and injectors, gates or not. I run the gates one in the race car and can't hear it at all. Obviously they would get noisier between the belt and idler/tensioner bearings if over tensioned Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/137/#findComment-7972202 Share on other sites More sharing options...
