6 hours ago, niZmO_Man said:
Sad to hear about the dog excrements in the ute. Should shoot three of their tyres yee haw.
Yeah, I live in an area once filled with bogans/housos. Their offspring still reside here, so you get an interesting lot.
Once I was crossing a road (in front of the Woolies carpark), using a  marked pedestrian crossing and this bogan chic (green station wagon Commo lol) reversed  down an one way street over the crossing then yelled at me for not looking.
Sigh, maybe one day I can afford to buy in a better area.
  • Haha 2
  • Sad 1
I'll give you notice where I buy my new house in just over a year, if you buy before that I hold no responsibility if you end up with a old Bogan who lives in your area
Love, The Bogan King
  • Haha 1
Let's waste money season.
Now with an additional 10AN fitting to loop back into the intake.
I managed to drill into the can and not dislodge any internal baffles, against what my fabricator said.
He did say I was brave, I then told him you should be more confident of your tack welds.
Anyhow, managed to slip a pipe into the 3rd baffle, theoretically this should avoid sucking up any liquid that gets spewed out by the stupid RB motor. The rest should spray onto the baffles and drop straight down into the sump drain.
Next is the turbo intake pipe, then send the lot back to the powder coaters to make me even poorer this month.
All this because I own a RB, meanwhile a 700kW 2JZ will have a $50 eBay catch can and it will be dry.
  • Like 6
1 hour ago, No Crust Racing said:
Any chance of swarf making its way into the pan?
has been cleaned out, I'll make sure to wash it again and again
  • Like 1
  • 3 weeks later...
Not working today, both kids are asleep, no calls from work, why not work on the shit box.
As we all know, non of the modern standard head units fit nicely in these shit boxes. In the past with my previous head unit and previous shit box JDMs I used foam seal tape OR use those door brush seals. Thought I'll try something different this time round, and bought a $13 fascia off eBay (bought it like 6 months ago).
With no real way to attach the stupid thing, I decided to hot glue the cnut on.
Needed to trim the top, but overall looks better than before.
Might need to trim a tiny bit off the top, but that's a job for another year lol.
  • Like 3
That means it's a level of love beyond the normal levels of care for an object.  It's your primal urge to maintain and care for it and nurture it back to health like a wounded dog.
I wonder at what point it became a primal urge for a bloke to start tending to the lawns around his cave/humpy?  They would have all laughed at the first Neanderthal as he sharpened up a stick purely for the purposes of tending to his patch of dirt!  Next minute everyone has a garden shed full of sharp sticks.  I digress.....  you love that bloody car!!  🤣
  • Haha 1
I have been meaning to do something about this too! Nice work!
I used foam tape in the past, I think I prefer this look more
  • Like 1
Used the shit box, took my son along for a ride. Loves a bit of dose lol.
Calls it a jet engine.
Okay, won't drive it for a while after this.
  • Like 2
2 hours ago, admS15 said:
I'm working on rectifying the situation.
Not enough dose lol..
Needs to go suuuuuuuuuu tuutuuutuu
They'll be hooked LOL.
  • Haha 1
Well that didn't last long, ended up taking it out again today.
Tiguan decided to run out of fuel on our driveway (slight decline), range showed 50km left lolol.
Useful shit box, kinda. At some stage, I'll get a custom slimline box made to go across the entire back trim, with a faux cover to cover up the surge tank lines.
  • Like 1
  • 4 weeks later...
Didn't win Powerball, can't buy a 911 GT3 RS.
Time to improve the shit box, so as we all know when you slap anything bigger than a stock pump, the OEM venturi causes a massive restriction, especially trying to control pressure on the rail.
When running a surge tank, you wouldn't care too much, however even with a 200L/h lift pump, there was still about 0.5bar of fuel pressure in the surge with the main pumps off.
This meant that the venturi was holding back the return line too much, building pressure for no reason, thus causing undesirable current draw, heat, noise etc.
So yeah, wasted more money to optimise something that would usually be over looked.
  • Like 1
I hate it, if someone came to me with a 2018+ F80 M3 Competition, straight swap I would take it and my wife won't complain because I didn't need to add in more money.
I've surfaced the idea of selling the shit box and adding money for a F80 M3, her words "get fked, you're not selling anything". She reckons I'll end up buying another 90s JDM shit box in the future.
  • Haha 1
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
