Next SAUWA Meet / Eat / Cruise.
Hello guys n girls lets kick this event category off in the forum.
Should be easier to follow than Wasteland.
Ok i mentioned about 2weeks ago to have a get together on 3rd 4th February.
3rd will be Friday and the big danny green fight is on.
So
Im thinking it would be a good idea to have it on Saturday 4th February.
I love this place and would love everyone to experience it.
http://www.highwycombetavern.com.au/
Great place
Big Carpark!
CHEAP FULL SIZE PINTS FROM $4.90 [emoji481] (please drink responsibly)
REAL WOODFIRE BIG PIZZA FOR $10[emoji487]
Friday are real busy but Saturday are ok.
Outdoor area for smokos and big screen
Indoor lounge with pub special.
And a restaurant option bit more formal.
Address:
530 Kalamunda Rd, High Wycombe WA 6057
Time:
1830
When:
4th February 2017
Who:
Everyone with a JDM
Rules:
Please read event sticky
Please reply if coming or any small changes like time. [emoji2]
1485869221739.thumb.jpg.d2a6e2e97b2d88c01485869201834.thumb.jpg.829be9e8c0376139
  • Like 1
https://www.sau.com.au/forums/topic/468874-next-sauwa-meet-eat-cruise/
Hello people that i don't know and just tagged you in this. I do apologize if you sold your JDM or moved states and want to forget SAU.
But im doing my best to make SAUWA big again !!!
Ill try tag about 45 but if 5 show up its worth it!
@dan_the_man@IMACUL8@Pal@antonio6183 @2fardown@EXEMPT@REMANIS@GODZILR32@mzlr32k@niran@R34@just kris@Diomedes_@StaceyR34GTT@Topaz @Mr.Keets @[YTRY4]@karbie@alvis@scarvo@chris260@Holly@TrevR32 @180j @mz.qiksky@Vinay1789@J3NKINS@MLCrisis@Sledge038@RBert@Wesley James R32GTR@YoLoBaCh@BiscuitTin@shane344@Socrates@Hattori Hanzo 69@L33SH@Josh080691@Footo@JH32 @ichi-go@PSIKO@tricstar@Hanaldo@jay-rod@Bren444@reNEGaDe88@Rekin@turboedsloth @10 4 @104@Nick_GTR@RB335@frostyboy@owen1r @sin-
  • Like 2
Ill try tag about 45 but if 5 show up its worth it! @Mr.Keets
Mr Keets has numerous JDM cars but is currently in sunny Africa, I'll let him know you've invited him though, I'm sure he'll be flattered :P
  • Like 2
I'll see what my work load is like. Will be in a jeep though as the 32 still isnt drivable
I'll try if I get my car back/get back to Perth on time
Drive Colin's to Perth and I'll bring ya home ;)
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
