Looking to Buy R32 GTR Need advice
so I have been in the market for a R32 GTR for the past few months now and and still undecided on what to do.
would it be better to buy a gtr that is in need of some work and fairly stock for $20k, or buy one with new paint, built motor, 300kw at wheels etc for 35k?
doing rust repair and gettting a new paint job wont cost me much a am close friends with someone in the trade.
how much would it cost roughly to get 300kw at the wheels? 10k?
thanks a lot in advance for your replies
https://www.sau.com.au/forums/topic/468943-looking-to-buy-r32-gtr-need-advice/
needs work in one area usually means needs work in maaaaaaany areas.
$30k on a vg condition "lightly modified" car and then spend money on basic go fast bits, ecu fuel system turbo ect.
Want advice when looking to buy an R32 GTR?!
Best piece of advice I heard many years ago was:
'If you can't afford to buy two of the R32 GTR's you want, then don't buy one!'
So very true...but do I regret buying one? Not for a second...
Is this true? I always thought it was what some owners say too 'Blow their own horn'.
i bought mine and promptly needed to spend maby 5k on random stuff. heater hoses, brakes, tires, this that something else, and nothing really gone wrong with mine.
i budget for either an engine rebuild along with new things like turbos and supporting mods ect as the engine will be out anyway.
or a gearbox rebuild + rear subframe out including diffs suspension bushes swaybars ect because again your half way their,
either way have $10-15k up your sleeve or available for when it does happen... not if....when.
their almost 30year old highly strung sports cars which were always bought as sports cars, their not gonna be cheep.
Quote
Can confirm, my car is already racking up bills like the turbo runs on $100 bills. It's not like it even goes anywhere!!!
Still, it's sweet to know it's mine. If it were me, and I were new to GTRs (which I was/am) go for the better quality one.
Perhaps a slight exaggeration especially in todays market where a typical example fetches mid 30's...but as Glyn has pointed out they are nearing 30 years in age and were basically a supercar when released, they weren't bought just to putt back and forth to the shops typically ;)
Basically what I was getting at is if you're scraping together every last cent to buy one then it's probably not the car for you, you need to prepare for the inevitable maintenance issues at a minimum (heater hoses etc...) then you get hit with the 'GTR' tax on most things you buy...
i can  afford a 35k gtr no worries just unsure what the smarter option is
Haven't seen an r32 gtr at 20k domestically that doesn't need a load of work. One atm on some facebook forums at 27k with a non original motor (r33 motor and looks rough), needs a full respray and there arent even photos of the interior either. Im sure 35k will get you one with minimal work (although theres always something not perfect, depends on what you are looking for).
17 hours ago, darkparagon said:
Well why do you want an R32 GTR?
I think if you can answer that then you will answer your own question.
If you just want one as it appears as though it's what everyone else wants or to just say you've had one then it's probably not the 'smarter' option.
But if you want one as it's the car you've always wanted and you're not planning to ever sell (or anytime soon) then I would deem it to be a 'smart' option.
Whatever you decide just be prepared to spend more money, the cleanest examples will still inevitably need money spending, don't buy one thinking you won't have to spend money on her. They're like a woman, even if you don't 'need' to spend money you will find yourself 'wanting' to spend money on her.
  • Like 2
Haha well put. I've been lucky with mine, only minor issues (coilpacks, AFMs) but the engine is standard. Spent a little bit of money on suspension and brakes, so it's a "budget" ownership for me. Unfortunately, if I checked the underside I wouldn't have bought it. Double edged sword.
I wonder how long before some of the "new" owners get over the "trend" and prices start coming down?
In all honesty I can't ever see them coming down, maybe stagnate but never go back down....It comes back to supply and demand.
There are far fewer cleaner examples these days and even less of the immaculate ones......and with the yanks now grabbing them this has been exacerbated.
This being the main reason I bought my SIL80 and my GTR will go from being a weekend warrior and hillclimb car to just a special occasion/weekend warrior...
Edited by mr_rbman
Buying a built/better condition car is much more sensible if you plan  on modifying down the track, however you might have to wait awhile. I looked at R32 GTRs/Evos etc for nearly 2 years and didn't find one suitable but you might be less fussy than I am.
My advice would be to wait, you'll end up spending much less in the long run if you modify. I'd also recommend to anyone who is looking at a R32 GTR to consider a Supra, better driveline than a R34 GTR with lower prices than a R32 (slightly).
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
