On 9/6/2021 at 6:48 AM, Dasmbo said:
Its still better than a std ecu everyone has there own choice in the end its only as good as the tuner and his equipment
For a street car I'm pretty sure the stock ECU is more advanced as far as engine protection goes
Nah. Not in the proper context. A street car could be quite modified. You're not running with a factory ECU on factory maps like that. So you dial out all the R&R that is up in the top RH corners of the maps (which is the bulk of the factory "engine protection". The factory put it there because they did not intend the engine to ever run there and figured that the only way the engine could get there was via a failure (ie wastegate line) or some Neanderthal futzing with the inputs.
But as soon as we turn up the boost we start to go into that part of the maps and need to clean them up. If you clean them up, then there is no more "protection". Just more map you can use.
The OEM knock detection and the strategies used in the factory ECUs (which varied from the R32 era of changing to the knock maps, which were even richer and more retarded everywhere than the R&R corner of the later ECUs, to just mapping in R&R and having a big timing subtraction applied in case that didn't work) works, so long as the knock sensors are telling the truth, which is not to be taken for granted.
  • Like 1
Not to mention the other things that you can trivially do these days to add protection with a decent aftermarket ECU, being oil pressure and fuel pressure, hell, even coolant pressure. These are all great even on a streeter, and far beyond what the factory ECU offers. If I had spent money inside my engine I would be seriously considering the aftermarket ECU approach rather than the Nistune I use now. When I decided to use Nistune I took the cheap option because it was plenty good enough for a basically stock engine not being pushed hard. Now, many many years later, with spare engines being a forgotten memory and the costs of fixing damage being a lot higher than they used to be, I should probably be reconsidering right now.
Oil pressure protection is a bit bullshit. Oil pressure protection didn't save our white 32 with the Haltech Elite last month at Morpowa.
How can it really ? Everything happens so fast with oil pressure that if it goes wrong, it's really too late for any "protections" to catch it before any damage occurs.
Depends, if you had a momentary oil pressure drop at the track around a big bend you could trigger that so can't rev the tits off the motor. Also depends on how you've set the strategy, there are timers you can setup depending on RPM and TPS position too.
I wouldn't call it bullshit.
Engine protection is useful, only when setup/used correctly. This happened to my old motor, I got the shits and dropped the minimum oil pressure requirement to 1bar.. guess who binned their motor afterwards :D
Its a "bit" bullshit.
That's sort of my point mate. If you set it too close to protect it will trip under normal operation. If you set it so it doesn't trip it may as well not be active.
On 07/09/2021 at 11:55 AM, BK said:
Its
well it wasn't really normal operation because around the bends I was sucking up air and hence the oil pressure dropped, thus it tripped.
I got the shits and lowered it and that cost me a motor.
And my point was to do with street cars, where an oil pressure problem could be either acute or chronic (ie something breaks or you're losing oil somewhere and don't realise it) and protection from the ECU would actually be more likely to save you than in a motorsport application simply because the engine isn't (usually) being whacked as hard.
Certainly more useful than not having it at all.
  • Like 1
Yeah, I probably should've mentioned that I meant factory ECU with Nistune or comparable method to change the map. I don't really consider having R&R corners of the map as "engine protection". Actual knock control/knock maps does count as engine protection though. AFAIK the RB26 ECUs also have a table for TPS vs RPM which will automatically short-circuit the MAF-based load calculation and skip straight to max load as a protection measure.
I dont use an apexi myself i have had a Wolf for the past 8 years now and was tuned at 473 hp and had it checked 2 years ago and still making 470hp safely and yes i still have the original engine block that the car came of the production line a lot of failures are caused by the driver not the equipment
and not to mention all the closed loop strategies for fueling, timing, boost, idle, air temp, air density, etc.. then there's drive by wire, launch control, traction strategies, etc... list goes on!
I know plenty of PowerFC fans here so I won't say anything bad because people will have a sads.
Yerrr but it’s got a hand controller display so u don’t need to have a fancy race dash 🤪
  • Haha 1
http://twinturbo.net/nissan/300zx/forums/technical/view/1127497/Z32-Knock-Control---Do-you-know-your-ABCs.html
Light reading on how the Z32s did knock control. Even in the 90s knock control was pretty decent, at least for saving the engine. It isn't quite as sophisticated as what you'll see in OEM ECUs today but it's still more advanced than some standalone ECUs out there.
so did the RB ECUs, hence the knock sensors and the S14/15 SR20s
And while it was reasonably sophisticated, it frequently didn't work. Many VGs and RBs ran on the knock maps all the time (and like shit, obviously) because the knock sensors were hearing engine rattles that the discriminators thought was knock. Either that or they went faulty and never heard knock even on an engine that was pinging like a 90s raver.
  • Haha 3
On 9/7/2021 at 11:58 AM, BK said:
Yeah I'm getting at "normal" motorsports applications which have fluctuations - it will not save you.
I mean, you could set it to instantly kill the motor before the oil pressure drops to a point where damage could occur.
But this is also potentially unrecoverable, if it drops at 7000rpm, the damage is done by the engine decelerates from 7000rpm to 0. It certainly wouldn't hurt in scenarios where you have *low* oil pressure in certain scenarios, vs say instant 0 oil pressure problems.
In theory you could tie this into an Accusump system. I.e if it's been triggered for more than 1S kill the motor, and let the accusump carry you through until your engine decelerates from 7000 to 0...
None of this applies to a PowerFC though 😛
PowerFC is as basic tunable ecu for fuel and spark. It's not that it's bad, RB's are simple engines electronically after all -  its that it's not really good value for money. Noone should buy one. If you got a car that has one already, that has already been tuned for it,  you may consider keeping it depending on your needs, but that's about it.
Their niche has been more than adequately covered by Nistune. If that didn't exist you could make an argument for a PowerFC if you got one very cheap.
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
