mmm, see what he says. I bought the springs and retainers from kelford, the blloody expensive beehive pecaloy springs so I would hope they are compatible.
I'll flick them an email for another opinion.
What valves seats are you using Dan? The stock ones can crack when combined with O/S valves
I will be using NASCAR valve seat rings with chromoly retainers.... definitely not titanium for my build, and no berrylium seat rings due to its incompatibility with E85
Continued the chat with Kelford.
Sent him pic of the retainers in question.
"It’s hard to see in those pics but that does look a little rough.
Titanium retainers wear when rubbing on a steel spring and base, there’s no escaping that. But if everything is under control then it’s hard to determine “normal” wear. I’ve had some of our retainers in my evo for about 30,000kms now and it’s had a hiding and you can see witness marks from where it’s been rubbing, but nothing I would call “wear” per se.
I haven’t got a hard and fast number for you sorry mate."
Asked if there was any special service interval or checks needed etc.
"Nothing written in blood. We have some race teams that check spring tension every round and others that check every season. We don’t have failures so I haven’t got a timeline.
We know what the retainer and spring have to control since we design both.  Your setup is a matched combo of cams , springs, and retainers. Where some other companies have problems is that they don’t design cams or even make them at all so they try to cover too many bases with one product and then they maybe get a spring that doesn’t cut it and it’s the poor retainer that cops it."
Consensus seems to be I should be fine.
Benny I didn't go oversized valves due to the increased risk of cracking in the head, I went Supertech valves for the better materials, SS and Iconel, but standard P11 sizes. P11 specifically for the thicker/stronger stem size but put into the better flowing P12 head (which also has the extra cooling jacket in it and flows more, but that cooling jacket means if you want max margin for safety you don't oversize the valves).
It's having chambers CNC'd ports are all  being ported as well so our heads are quite different. DET/VE head flow characteristics are very different stock, once ported even more so.
As for seats, standard were used in this as P12 seats are more than adequate for the application so says the builder and Kelford and that was knowing full well I was happy to spend if it needed it.
Dale hopes to collect the head today he reckons. I'm keen for some pics.
  • Like 1
Did Dale remove the squish pads in the head?
Also, I'm not talking about my DET Build ;)
Something else is in progress....
Update your build thread, I'm sure it'll be megadon, you always go extra large :D Keen to see a 1000hp SR so someone has a chance to keep up with the K swaps lol
Received some pics of the CNC work tonight, looks good to my untrained eye, but I will post pics when it's complete.
Sooo after almost 100m of tape, the insulation is now finished to my standards. It comes with double sided tape on it to hold each piece to the next, but I remember from last time it doesn't handle the heat cycling well and fails, then you get gaps as can be see in one of the pics below, starting already.
If you leave it too long and you get a layer of dust etc on the surface it's then much harder to get good adhesion with the better tape so I went ahead and just did the whole shed pre-emptively. Also cut out a couple inserts for the whirlybirds for winter mode to keep the heat in.
Also going to replace the pot belly, which never impressed me much, with a fan assisted Coonara (which even has a secondary burn tube in it) because I like watching the flames and it'll put put more heat more easily. I could add a damper and secondary burn to the pot belly, but wood heaters are by and large just a lot more efficient.
Plus random ladder shot of Silvia because I was up there so much.
 20210626_204424.thumb.jpg.8e7dd80509b819cb7cbf138b2d35fdff.jpg20210626_211411.thumb.jpg.b6999706e059772ba380fb5b47c22b8a.jpg20210626_212929.thumb.jpg.8ad3faa2c03ef8d47d20867eef2a5375.jpgNo description available.No description available.
  • Like 3
Looks good, I've got the same insulation in the garage (sans tape) and it is the warmest building on the property.
I've resisted putting a wood burner in the work shed because it is kind of a statement that I'd rather spend hours out there at night than back in the house...they are excellent/cheap but not quick to get up to temp....instead I just freeze my arse off all day and slink back into the house before it gets too cold at night
Pot belly might take hours but a proper wood heater doesn't, we are mostly wood heating in the house so I'm very comfortable with how to use them.
It's actually mostly for social gatherings. Watching racing, pool/table tennis, beers with the boys etc.
I don't recall ever putting one on to work, I just wear a jumper and keep moving lol
No Crust Fabrication hard at it doing some maintenance on the Coonara before it goes in.
Burn tube was toast, made a new one and fitted after straightening the baffle. 3 out of 5 welds were nice, the other 2 were ugly AF but seemingly strong - 3mm steel so quite forgiving for the learner that I am (this is my 2nd or 3rd ever welding project).
Front door looks like it might have seen a little water damage from storage or maybe just metal fatigue from age. Cut that section out and made a new piece, welding in is proving a little harder as I was putting holes in both materials even on my lowest setting, it's only 1 to 1.6mm though. Spoke with a mate of mine who said you just wanna tack it, move to another section, tack again etc and continue as the metal will heat up too quickly then blow holes through.
I have the piece "in" but it's not pretty, spent some time cleaning up that work then will give it another pass and tidy it up again.
Going to give the heater a once over with a sanding disc and smash a coat of high temp on it for good measure.
Door section repaired, just need to tack in a couple sections that set the height of the glass and I'm right to start cleaning the unit for a lick of paint.
This was quite interesting/challenging working with thinner materials, needing to tack, move, tack, move.
I noticed that lower section of the door has not got a light curve in it from the process, should be fine but might need a gentle twig to get it back. Will have to clamp it down properly next time.
Also the rust that came off when sanding/moving it etc seems to have stained the floor, as in still lightly visible after a basic wipe over. See if it wipes up with a basic cleaner/water/whatever. I also dropped a piece of steel and chipped the concrete, shed is no longer virgin.
Dale tells me th head should be back hopefully this week, the Sydney lockdown causing grief.
  • Like 1
Heater coming along, just waiting on door glass seal now and we are good to go.
Got a dry day over the weekend so chucked the flue in. Hoping to christen it this weekend with the boys in the shed for some drinks but lockdown looms.
Bought myself a drill attached nibbler for this job, can't say it worked that well on the corrugated metal, hammers through it until the angle changes too much though, ended up cutting the whole out in sections then using the grinder to clean/final shape.
Head is still at the CNC shop, have seen some progress pics but bloody hell is it slow progress.
No photo description available.No description available.
Edited by ActionDan
  • Like 2
When you're done making big bucks in the city you can move regional and live like a king :D
That seems to be the way here, which makes it harder for people who were always regional, like me, to afford to buy the houses because you city folk are buying them all up lol
  • Like 1
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
