Advice/Recommendations: R34 Suspension repairs + coilovers
Hey guys.
I took my R34 GTT to Pedders for a full Brake, Steering and Suspension check after noticing some changes in my steering and road feedback.
Turns out I need about $1300 in wear and tear repairs, and I also need to replace all 4 shocks.
They said the only company that would make shocks for my car would be Bilstein and I'd need to get their Sports range which would end up costing me a fortune, and I'd be better off getting coilovers.
They quoted me $1900 extra ($3200 for everything) for their own coilovers. But they reckon the maximum ride height of their coilovers is slightly less than my current height (factory height), and I really don't want to lower it (my baby is all stock after all).
  1. I would prefer to get a full coilover conversion than just replace the shocks, but does this mean I will need to lower it a touch?
  2. Are the Pedders coilovers good quality? ie would you recommend them? or if not, who should I look at?
  3. Is the price quoted reasonable?
Thanks for any and all advice!
Edited by Akuma07
If going coilovers for Street driving, get some mca blues. They are cheaper (around 1650) and would be better than the pedders. I wouldn't be scared of lowering it a touch, say 30mm. If you look hard enough you could probably find some kyb brand standard replacement shocks. Pedders may not be able to get them but they are available. Whatever other components pedders quoted you for could probably be sourced for half the price and fitted elsewhere for a lot less. They do have to make a dollar after all.
EBay is your friend to check pricing and for supply of parts. Just stick to the known branded products and reputable sellers. The old way of picking up the phone and ringing around to suppliers can also work well sometimes.
  • Like 1
Other places in sydney who can source and it suspension set ups - worth calling/email both to see what they can offer you at your budget.
If you are able to get coilovers, it's always good to try and have it fitted, aligned and if you can afford the $400 extra, cornerweighting which is essentially adjusting the height to fine tune the weight distribution across the front and rear of the car, this can make even cheap set-ups work really well.
Sydney suspension
https://www.facebook.com/SydneySuspension/?ref=br_rs
Review here - https://www.youtube.com/watch?v=vwfZrxXGTlg&t=450s
And Heasmans;
https://www.facebook.com/HeasmanSteering/
Sydney suspension
And Heasmans;
Thanks for that. I might ring up the guys at Sydney Suspension. They've got a lot of good reviews and live right by me.
MCA Blue for sure. Contact MCA, tell them you after a comfortable street setup for your R34, they should send you a correctly set up set of suspension.
As mentioned, cheaper alternative is KYB replacement dampers.
Though I'd post in this thread also for anyone out west looking for import mechanics/suspension work.
https://www.facebook.com/TransformanceMechanicalEngineering/
Give these guys a ring, they up your way in springwood, they look after everything from suspension, mechanical work to tuning, they are also dealers for MCA coilovers, could be a good one-stop-shop option for you.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
