Got the airbox mod 3d printed and temporarily screwed it on as it's only minimum infill for trial.
Fits perfectly and the cold air inlet sits just outside the main frame rail.
Also modified the power steering reservoir by making my own bracket as it didn't clear the bonnet when closed in the stock one.
  • Like 2
So I got it going today but have a few issues.
Turbo coolant hose has split, kinda knew it would.
Power steering keeps leaking at the pump so just going to use the old setup
Crank position sensor is throwing a code so it could be f**ked
It keeps overheating. Doesn't matter what I do, i can't get it to not overheat.
Edited by Sack87
1 hour ago, TukeH said:
Whats that strange cliking sound is?
When the water hits the power steering belt it makes that weird noise. You can see the water spitting out of the radiator neck. Took me a few minutes to figure out what it was haha
Edited by Sack87
17 hours ago, Akshunhiro said:
Nice work with the airbox. Would you mind sharing the STL? Or, can I buy one off you? My 3D printer is still waiting to be assembled haha.
Let me test it out first to see how it goes with the heat, then I'll look at selling the STL file if it doesn't melt haha
It only just fit on the Makerbot Replicator bed so yours needs to be the same size.
So I got the coolant bled to a point where I could drive it without overheating and run the engine in for 100km.
Installed a GFB G Force 3 boost controller on a little bracket I made up that fits in the vent. I can monitor AFR later on when I put another sensor in and protect the engine incase it leans out. So many cool features with this unit.
Also had a mate dip the grill in carbon fibre. Came out really good and matches nicely with the ARX kit.
  • Like 4
  • 3 weeks later...
I haven't had much luck with the car as of late. Noticed there was engine oil coming out from the bell housing and whilst under there, I also noticed oil coming from the turbo between the cartridge and turbine housing.
Pulled the box out haphazardly as I didn't have a hoist and pulled the turbo back off too. I cut the rear main seal by accident when installing it on the stand without being able to see the back of the crank. Turbo went back to MTQ for warranty and they reckon nothing was wrong but replaced the oil seals.
Fitted new rear main which is an absolute f**k to get in there and box and turbo back in for test drive.
I put new viscous oil in the fan hub last night and it works/sounds like it's moving a lot of air now. Went to go for a drive, look under the car for leaks after putting it all back in andddddddd oil is pissing out of the turbo feed banjo. FML. I checked every fitting was tight before I put it back in so MTQ have done something there.
So today I started pulling the turbo back off again to fix that.
20 minutes ago, andynogo said:
Yeah... It's one thing after another hey. Keep on trucking- you'll get there! Half price boost night 17 April at whoop ass... Might be a few of us going...
I would but i'll be on arvo shift. I plan too make it down there soon before seasons end.
So it's back in business, no leaks so much success.
Hob drive still says its overheating though but the gauge does not move whether it's 75 or 105.
The new fan oil helped a bit but I think it might be a faulty sensor.
  • 3 weeks later...
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
