4 hours ago, fatz said:
Should also say in America where all the epic numbers come from their ponies are smaller than the rest of the world so this may also lead to disappointment cause it didn't make 400kw
The fat man is correct.
Here is 1 American hp
  • Like 5
  • 3 months later...
36 minutes ago, MattSR said:
What brand of trigger disc is that?
This particular one is just made here locally in NZ - just as a cheaper alternative to the ross ones you usually see. CNC'd disc and a bosch sensor. $380.
  • 5 weeks later...
1 hour ago, Komdotkom said:
Any news on this? I'm keen to hear if you have managed to pick up any hidden hp with the altered trigger.
I'm still hoping that there's a way to get the IWG EFR's to make decent numbers.
Car is just about to be painted following on from some rust repairs, will be tuned on E85 after I get a bigger fuel pump in there. I should have something within the month provided the tuner is available.
The IWG didn't cause any problems for me apart from the actuator bolts on the arm coming loose.. the boost control was fine there. Will likely be getting a harder spring too before the tune. Will be good to see what happens when we can add more timing down low and see how aggressive it can really come on!
Sorry for the lack of updates!
  • Like 2
  • 8 months later...
Updated results, still 98octane with the updated cam trigger.
Skinny red trace: Old tune low boost
Skinny green trace: Old tune high boost
Solid green trace: New tune low boost (10.5psi)
Solid red trace: New tune high boost (21.5psi)
ECU onboard MAP sensor is limiting boost.
Edited by Dievos
  • Like 4
So that means? Am I guessing right that 75% of the improvement is fuel as E85 masks the high back pressure and any inefficiency in the setup and just gets busy making numbers? Then may the tune with more accurate ignition?
I know my old setup loved going to E85 as it simply allowed more boost and ignition everywhere over 98 when the thing just became too prone to detonation. E85 seems to make inefficient air pumps work a load better.
Looks a far better result and imagine drives like a different beast
What it means is that the car does not have any issues continuing to make more power at high rpm - this set up made as much as 368kwatw with power actually wanting to increase but was out of the knock threshold for 98 and we couldn't try more boost as the ECU MAP sensor was maxed. Boost control does not spike when it reaches full boost and the control tables are still quite basic.
Edited by Dievos
  • Like 1
So more accurate ignition control paid huge dividends.  That's great news.
98 fuel is the current limiting factor, and to run more boost you will need to pull timing to keep it together?
Mid range torque looks like it should pull hard off corners with awd traction capability.  Very good - must be very satisfying to drive.
Wonder why torque drops so noticeably around 62-6400?  Very similar trait to RB25. Be interesting to see what EMAP looks like
On 12/16/2018 at 10:31 AM, fatz said:
this Australia or nz cause that’s mythical power on 98?
Power sounds right, it's on a hub dyno. Put some wheels on it and drop it onto a Mainline and probably read about 15 to 20kW less.
Put it onto a Dyno Dynamics and it will read more power (especially if the ambient temp sensor is disconnected or left near a heat source lol).
  • 8 months later...
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
