17 minutes ago, r32-25t said:
Including your wallet
It’s a few hungered more than a gen 2 GTX. So after buying gates, manifolds, lines blah blah it’s almost insignificant.
1250cc would be plenty,, also they're easier to fit as they're 3/4 length not 1/2 length like the 1300/1550/1700 injectors out there.
Okay sweet thank you, what size gate should I go 45mm with a 14psi spring? Was thinking of going with the hybrid top mount manifold and the proflow ffp?
Going of gcg website a gtx3582 gen2 is $3140 and the efr8374 is $3810.
Now I’m sure both could be found cheaper but it’s a price anyone can search and see I’m not just pulling numbers out of thin air
  • Like 1
FFP also isn't exactly needed, i.e save your money.
GTX3582 and 8374 are gonna be too laggy for a motor that only revs to 7k. Unless you rev it to 8k, in which case see earlier comments re: "Stock motor compatibility". Think full boost at 4500RPM and see earlier comments re: "RWD"
Excellent for GTR, especially ones already had a rebuild. If you're smart you can mount something that'll do 350+ every day to the stock manifold location and not need a FFP, not need external gates and their plumbing/exhaust and not need a rebuilt motor for much longer and also have such useful features as "having grip" and "boost well before 4k"
FWIW I was told in a single gate setup you'd need a 50mm gate. I have one and it works quite well actually, can run as low as 10-11psi. Keep in mind you also have a R34 so clearance in that region for big exhausts and EWG's and screamer pipes may not be compatible with "Air conditioning" unless you have a fabricator with a lot of patience.
All of that for 20kw you wont notice and lack of a million things you will
if you ever want to make 500kW I have a brand new motor that's never started before sitting at home...
Kind of over it.. so if you come give me enough cash you can take the lot and if you give me enough I'll throw in a free car with enough track suspension mods you'll cum your pants.. all it needs is a roll cage and will be competitive.. has Brembo brakes too.
Inboxed
19 minutes ago, sergi_dee said:
Maybe I'll do just cut and shut and relocated the throttle so I have shorter pipping and don't have pipes over the motor.
No no no no.  The Nissan plenum is designed to be fed from the centre, not the end.  No-one who bastardises the factory plenum ever seems to think of this.
There's nothing wrong with pipes over the motor.  There's nothing wrong with the "long" length of pipework.  Any such perception is faulty.
  • Like 1
Ahaha okay just because so many people do it thought it was a good and cheap move and to shorten them pipes. What about the freddy plenums? Just because when I go top mount it will interfere with the piping
Nah, look at @klutched's build has stock plenum and high mount.
  • Like 1
Imo if you must go high mount and ffp run a GTX3576R with T4 twinscroll mani with divider all the way to a 45 or 50mm gate. For FFP get a Plazmaman plenum from @Dose Pipe Sutututu
You can use stock mani and do a custom crossover pipe like ive done. They stock intakes will flow more than you are asking. Im at 374rwkw 20psi with a GT3076r Hypergate45 1000cc injectors, CRG highmount, 256 cams, gasket and studs. Would wind it up more but compressor is flowing its dick off. Ive seen a few guys with gtx3076r's get to 400rwkw but 27-30psi.
For cams throw in a set of 260deg cams and valvesprings to keep it responsive and add some mid/top end power.
  • Like 1
Would give you a good start! Turbo is like new as has only done a handful of laps since a new fresh rebuild. Responsive and could make 400kw if you really want to ring its neck! Best i saw was 392kw out of one but was responsive and fast!
Inbox me as im interested in your turbo
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
