2 minutes ago, sneakey pete said:
If you go a 3788 you'll have even more headroom... but then again a 4202 would be future proof :P
well.. if that's the case might as well drop in a LSX and run 2x of those turbos :)
Done!
Thanks for all of the replies.
I see the Hypergear stuff is strongly suggested.
i'm looking at this: http://www.hypergearturbos.com/index.php?route=product/product&product_id=57
ATR43 400~600HP T3x Internally gated turbocharger
Would I need to send my turbo in to Hypergear or is this a whole new turbo? (can i part-exchange my turbo? Else I got no use for it)
It is almost direct bolt on.  You will need oil and water lines.  Tao can supply those with the turbo, or you can look at eBay....but easier for you getting them from Tao.  The dump should match Nissan pattern.  The inlet needs modification.  You can't use the skinny rubber Nissan shit.  You need to fab up a steel or alloy 4" inlet that will also accept the AFM and your BOV return, etc.
you dont need water or oil lines with the 43 and 45 atr's. it just makes it a little easier to install with them.
There is a bit of custom involved, as gts said. But nothing serious or hard. And depends how neat you want it... Get some more pipe, a 90deg bend and some random silicone joiners and you should find a nice combo.
Get BB If you want better spool. I'm all in at around 3500 with journal with the atr43g3sat.
Install process:
FYI: You need around 60mm studs, not 40mm. Also there are easier ways to do the install than shown below.
I'm holding off on the turbo for now.
A buddy may be able to get me a NEO motor complete with turbos.
Would that just be a simple matter of removing the existing RB25DET and replacing it with the NEO? Is the wiring harness the same?
Luckily I wont be doing the work. Will send it to my buddy's shop but I will help so I can learn at the same time.
No, the wiring is not the same.  There are differences at various sensors.  The Neo has a boost sensor for the ECU that the vanilla 25 doesn't.  You need the R34 loom and the R34 ECU.
it will probably be easier for me to get an aftermarket ecu.
these cars are rare in south africa. especially the r34
if i do find one however I will get it
Edited by Die$eL
ok so my buddy just called.
He is able to get me a complete NEO motor with auto box, ecu and harness
would it then just be a matter of me replacing my engine, ecu and harness (not gearbox).
Is the ecu for the automatic cars "linked" to the gearbox in any way? Or would it just be a matter or fitting a resistor for the shift solenoid?
The R34 TCU is in the ECU.  And that's fine, because it doesn't matter - it will run a manual trans engine happily.  You're going manual right?  Because if you're not, punch yourself in the face and start again.
If you use the R34 ECU you WILL want to get Nistune installed in it, because you will want to kill the error codes caused by not having the right ABS and TCS systems installed in the car. And you WILL want to tune it.  All of which, happily, Nistune enables for you.
Assuming you go Nistune with the R34 auto ECU, which is the smartest option for what you want,  You can turn all the auto specific flags, so the ECU no longer looks for it, therefor you won't see any CEL codes.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
