On 22/04/2018 at 10:18 AM, Easto said:
Yes in all her beaten glory.... If it makes the second session I'll be surprised lol
If only Oran Park was still here. Miss seeing it out on North circuit
  • Like 1
How many spots are left?
My car might just be ready in time and I have 2 mates who are 100% in if I can make it. We all have cams licences, so its just a matter of me running my car in.
I spectated last year, and was a perfect event so would love to come.
We still have plenty of spots, we are at about the 1/2 way mark.
  • Like 1
Ok guys bit of a pickle, i have figured out what to do with the fire extinguisher but the tow hooks are the next thing for me. Rear is accessible but what to do at the front?
Total track newbie here.
I've seen a few people use a tow strap for the front. It looks like a seat belt type material.
On 4/18/2018 at 5:25 PM, G3TFKD said:
Thanks for following up.
Max would be 5.
I've got 3 definite and 2 tentatives
Any word on you and your mates signing up man? One member unfortunately cant make it now - we now have a paid spot to fill!
***ATTENTION ALL ENTRANTS***
If anyone else is going to register, but hasn't done so yet, get in contact with myself or @crashdown before you do - we have one non-member spot that needs to get traded, and can figure out an arrangement with either a member or non-member entry!
Yeh sorry mate. I've been getting smashed left, right and centre with a new baby and work.
I'm out for this one. Too much going on at the moment and my car is not ready to go.
My mates are indicating like they are dropping out as well.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
