Debating going to a Spool spline Drive oil pump gear setup, has anyone seen any failures, weird wear?
I currently have a Tomei Pump, Recently broke the Snout of my crank off at the track (no idea why) this has me thinking about switching to a different perhaps better setup.
Whats everyones thoughts on this these days..
There’s quite a few workshops in Melbourne who’ve used them with N1 oil pumps for years now. From Rb28’s to RB34’s. No failures or breakages, have run mid 7 second passes well over 1000hp and 8500rpm without issues and still going strong. Wish I did it when I had my motor built
  • 1 month later...
If you have a Tomei Pump you do not need to scrap it. We supply a full conversion to Spline Drive. You would be better off with a Tomei as it it a better overal Pump.
I went with the Spool gears, yours are almost double the money.. i agree the Tomei pump is a better housing however.. having that much flow seems to cause more issues then it fixed..
Edited by mitchum
3 hours ago, burn4005 said:
I'm confused, a tomei rb26 oil pump is a spline drive. What Harmonic damper were you using when the snout snapped?
Its still driven by the conventional method 2 flat spots on drive.. there are splines on the Tomei gears but not technically a spline drive.. my Tomei didnt fail me however it got pretty beat up with the crank snout breaking. I was using a Ross pulley.
I went back to an N1 pump housing i ported the entry and exits so it flows a little easier..
Tomei pump is good and all but having that much flow isnt really needed IMO.. causes more issues than it fixes with oil pooling in head and or sucking sump dry... Stock VG30 pumps and 2JZ pumps work just fine for 1000hp.. no reason a properly driven N1 pump cant supply a sufficient amount of oil.
  • Like 2
  • 2 months later...
I have installed the Spool spline drive gears in a New N1 housing that i ported a bit. Its in the car and running. Seems to be working well.
My only concern was the fairly low pressure at idle.. used to be about 20psi with the Tomei. It is now at around 12psi hot.. but goes up quickly with revs so should be fine as long as it doesnt go any lower.
This engine should make north of 800whp so report back if anyone wants updates.
  • Like 1
Would be good if you have a few pics of the work on your pump housing?
And with the hp level, presuming you might have the right sensor setup to log oil pressure?  Be good if you can post up a log run to show oil pump performance
FWIW (might not even be on-topic) but I also decided to NOT go the spline drive route, after reading countless forums, blog posts, watching fat Jim talk about oil pumps and shit it seems the general consensus is that the spline drive needs the motor to have perfect tolerances, etc.
Most of the time when we build motors, we all end up line boring the block, this "generally" shifts the crank position by a bee's dick and because your oil pumps cannot be shifted that direction by whatever you end up unevenly driving the spline drive.
With my new motor for the shitbox, I just re-used the OEM NEO oil pump (which I believe it similar as a N1) and used the Spool billet gears. Crank was machined down, and the extended collar fitted with 2x grub screws.
I also run a host of sensors and can log oil pressure vs. engine speed vs. oil temp and water temp for anyone interested. It's on a Haltech Elite with no additional boxes (no need to insert Haltech box jokes). Happy to post whatever data people want :)
  • Like 2
  • Haha 1
This is exactly what happens when you line bore, and when you do go spline driven pumps you are meant to take out the locating pins on the block for the oil pump. Install the pump, finger tighten the bolts turn the crank a few times to center it up and then tighten the bolts to spec.
I just blended the entry and exits inside the pump so they would flow better than a straight sharp edged hole.
I used a dial indicator to setup the pump, drilled the dowel holes larger in pump housing and centered pump over crank with 2 dial indicators. What ive noticed over the years of building these engines is even from the factory..  the alignment isnt spot on, which could be the reason some guys get away with stock oil pumps alot longer than others.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
