Has anyone done a back to back dyno comparison on changing the rear housing over, i have had a good trawl of the forums and can't find anything within the last 10 years.
Currently have a .84 on RB28 doing 800whpish at 30psi however it has hit a bit of a wall, looking at going to 1.0 or 1.15 to make slightly more top end.
Current graph below don't mind loosing a small amount of that midrange ?
https://www.sau.com.au/forums/topic/476580-rb28-6466-ar-change/
On 4/9/2019 at 6:17 AM, GTScotT said:
Firstly, do your cams and head allow for more?
By my eye I think the nose over is more mechanical than it is in the turbine housing.
Winding more boost in just resulted in it dropping off in the top end, leading to believe back pressure is the issue from the rear housing.
Cams are HKS 272's minor touch up work in the head to accommodate the new cams.
Really keen to follow the rear housing comparison as the turbo needs to be rebuilt in anycase, so is cheap top end power but I want to see at what cost of the bottom end in rpm terms.
A chap I know has tried all of them, actually just tuned a car running a 6466 with a 1.00 and is looking at going 1.15 - said the difference in flow between .84 and 1.00 is significant in itself, picked up a LOT of power "pound for pound" when going north of 20psi and only lost about 200rpm on a stock stroke RB26.  It's holding peak power at around 8000rpm with the RB26 at ~650awkw on a Dynapack on E85.   He is pretty certain the 1.00 is a better balance of response versus power than the .84 even on an RB26.
  • Like 2
My setup has the same issue with the 1.00 6466 choking the 3.4lt.  705whp at 5500 rpm till redline.  It seemed the hot side was just completely maxed out, at 30psi.
I've got 1.3 housing here to go on the car which should really liven it up in top end and make it a little less savage in mid range.
  • Like 2
would love to see some graphs if available
1 hour ago, 33GTRV said:
I have a 2.8 with a .84, it's a f**king weapon on the street mate, are you racing the car? I have a conservative 500awkw and I regularly get turfed from the track even on a roll through.
car has gone 9.6 @ 146mph
In terms of goals it is pretty much done, however it looks like we are leaving some power on the table.
car gets used for everything from circuit / drags / runway racing and streeted so is an allrounder. I don't mind loosing a small amount of bottom end for top end gain, however just trying to quantify the impact. Sending the turbo off for rebuild shortly, will more than likely just do it.
149 mate. 140 to 144 with street suspension, 149 and as high as 151 with bone stock suspension and a good wheel alignment. The track here is very very very good to the 1/8th, one of the fastest in the southern hemisphere, which suits the datsun well. What suspension are you using?
interesting what times did you trap also? do you have the slip? keen for more details on your car to compare notes, do you have a build thread?
  • 3 years later...
Bringing this bad boy thread back from the dead. I'm just about to purchase a 6466 and I'm also stuck between ordering a .84 or a 1.0.
I was leaning towards a 1.0ar but being that I'll be running on pump gas + meth as opposed to E85, I'm worried about spool. This is on a 2.8 with VCT, 272 cams and a fair bit of porting. Goal is 600wkw on a mainline dyno.
The .84 rear on my stock bottom end 2.6 with vcam and e85 was all in at 4,100 and was an absolute weapon on the street, I only used the high boost twice and once it tried to kill me (turned out to be a transfer issue)
  • Like 1
1.00 or 1.15.
  • Like 1
No smaller than 1.00 on 6466. Dont worry the 1.00 a/r is not too big, I'm  running on both the 32s. Stock cams and 2.6 or the 2.8 and big cams are both great to drive as it's just such a flexible turbo.
  • Like 1
I lost nothing going to a 1.15 and did just over 600kw on E85 so you should be fine
I am actually moving to a smaller 6062 turbo shortly if you want to buy my 6466 with a .84 and 1.15 housing, it was rebuilt by precision in america in feb this year, been used about twice since.
I am going smaller as i am doing more rallysprint style stuff these days, and can get alot more down low and 500kw from a 6062 which is what we need for rallysprint.
  • Like 1
Thanks for the info. I would buy it from you but I'm presuming you're not anywhere close to Canada and shipping would put your price into new turbo territory. 6466's are had here for 2650$CDN new to the door. Let me know, thanks.
  • Like 1
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
