Has anyone done a back to back dyno comparison on changing the rear housing over, i have had a good trawl of the forums and can't find anything within the last 10 years.
Currently have a .84 on RB28 doing 800whpish at 30psi however it has hit a bit of a wall, looking at going to 1.0 or 1.15 to make slightly more top end.
Current graph below don't mind loosing a small amount of that midrange ?
https://www.sau.com.au/forums/topic/476580-rb28-6466-ar-change/
On 4/9/2019 at 6:17 AM, GTScotT said:
Firstly, do your cams and head allow for more?
By my eye I think the nose over is more mechanical than it is in the turbine housing.
Winding more boost in just resulted in it dropping off in the top end, leading to believe back pressure is the issue from the rear housing.
Cams are HKS 272's minor touch up work in the head to accommodate the new cams.
Really keen to follow the rear housing comparison as the turbo needs to be rebuilt in anycase, so is cheap top end power but I want to see at what cost of the bottom end in rpm terms.
A chap I know has tried all of them, actually just tuned a car running a 6466 with a 1.00 and is looking at going 1.15 - said the difference in flow between .84 and 1.00 is significant in itself, picked up a LOT of power "pound for pound" when going north of 20psi and only lost about 200rpm on a stock stroke RB26.  It's holding peak power at around 8000rpm with the RB26 at ~650awkw on a Dynapack on E85.   He is pretty certain the 1.00 is a better balance of response versus power than the .84 even on an RB26.
  • Like 2
My setup has the same issue with the 1.00 6466 choking the 3.4lt.  705whp at 5500 rpm till redline.  It seemed the hot side was just completely maxed out, at 30psi.
I've got 1.3 housing here to go on the car which should really liven it up in top end and make it a little less savage in mid range.
  • Like 2
would love to see some graphs if available
1 hour ago, 33GTRV said:
I have a 2.8 with a .84, it's a f**king weapon on the street mate, are you racing the car? I have a conservative 500awkw and I regularly get turfed from the track even on a roll through.
car has gone 9.6 @ 146mph
In terms of goals it is pretty much done, however it looks like we are leaving some power on the table.
car gets used for everything from circuit / drags / runway racing and streeted so is an allrounder. I don't mind loosing a small amount of bottom end for top end gain, however just trying to quantify the impact. Sending the turbo off for rebuild shortly, will more than likely just do it.
149 mate. 140 to 144 with street suspension, 149 and as high as 151 with bone stock suspension and a good wheel alignment. The track here is very very very good to the 1/8th, one of the fastest in the southern hemisphere, which suits the datsun well. What suspension are you using?
interesting what times did you trap also? do you have the slip? keen for more details on your car to compare notes, do you have a build thread?
  • 3 years later...
Bringing this bad boy thread back from the dead. I'm just about to purchase a 6466 and I'm also stuck between ordering a .84 or a 1.0.
I was leaning towards a 1.0ar but being that I'll be running on pump gas + meth as opposed to E85, I'm worried about spool. This is on a 2.8 with VCT, 272 cams and a fair bit of porting. Goal is 600wkw on a mainline dyno.
The .84 rear on my stock bottom end 2.6 with vcam and e85 was all in at 4,100 and was an absolute weapon on the street, I only used the high boost twice and once it tried to kill me (turned out to be a transfer issue)
  • Like 1
1.00 or 1.15.
  • Like 1
No smaller than 1.00 on 6466. Dont worry the 1.00 a/r is not too big, I'm  running on both the 32s. Stock cams and 2.6 or the 2.8 and big cams are both great to drive as it's just such a flexible turbo.
  • Like 1
I lost nothing going to a 1.15 and did just over 600kw on E85 so you should be fine
I am actually moving to a smaller 6062 turbo shortly if you want to buy my 6466 with a .84 and 1.15 housing, it was rebuilt by precision in america in feb this year, been used about twice since.
I am going smaller as i am doing more rallysprint style stuff these days, and can get alot more down low and 500kw from a 6062 which is what we need for rallysprint.
  • Like 1
Thanks for the info. I would buy it from you but I'm presuming you're not anywhere close to Canada and shipping would put your price into new turbo territory. 6466's are had here for 2650$CDN new to the door. Let me know, thanks.
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
