Brembo's fitted and dummied up the new intake and intercooler pipes.
Will tack the pipes next weekend and get onto the catch can mounts and lines.
Also looked at a mates GTR fuel lines, decided I'm going to redo the fuel lines in the engine bay before tuning.
Hopefully fire it up the last weekend of June.
Edited by Wheezy
  • Like 1
I booked the tune for July 21.
The new ECU is being sent here along with wide band, air temp and 4bar map sensor.
I will install it all prior to the tune, so about 4-5 weekends of solid work on my hands.
I remade the fuel lines to the rail as I wasn't happy with them and based it off a mates GTR who has comparable power levels.
I fitted my hose separators and made up the catch can lines, I'm getting quite fond of 200 series now.
The catch can previously sat on the battery tray which is now gone, so made some brackets to mount it.
I might remake one of the brackets as the catch can sits on a slant due to the engine bay shape.
  • Like 3
  • 3 weeks later...
The Emtron is wired up & can bus working thanks to my brother in law.
Seems to be doing it's thing, the Emtron is a vastly different beast to the old PowerFC.
Put some oil in it and the engine turned over which is promising.
I didn't get to start the car this weekend as we found a water leak on the intake near 1&2, so I need to take a look at that before firing it up as I want to be 100% sure everything is kosher.
Since I cannot see the leak the intake chamber and throttles will have to come out at the very least, worst case the whole plenum will come out and get RTV on all the things :(
Gauge wise for now I'm using my old Defi Link screen for water temp, oil temp/pressure & fuel pressure for now until I can afford to go 7" big boy screen & run the equivalent sensors through the Emtron.
I may even do an electronic speedo off the Emtron since I wont be needing the cable once I have a LCD dash :)
Edited by Wheezy
  • Like 2
Found the intake water leak & have ordered some metal gaskets this time rather than the genuine paper ones.
Will pressure test the system before putting the intake chamber back on.
Got a new blade for my band saw & finally got my tungsten rod order (hard to get right now) so whilst I wait for gaskets I will finish my intake pipe this weekend :)
Edited by Wheezy
  • Like 1
Got the dash back together and the ECU mounted today.
Will test to see exact where the leak is coming from with this China eBay pressure tester kit.
Going to get the leak sorted out in the week and try to finish the intake pipe to the turbo.
Edited by Wheezy
  • Like 2
20 hours ago, Roy said:
Looks neat. Seems us R32 owners are now the bird-dog owners with all the 31 owners going full bling instagram spec :)
Keen to see this thing back and extracting everything the T67 can give !
Thanks man.
Having said that, your 32 is an exception to that rule!
The new turbo is a TD06SH-25G, so should have a tiny bit more poke up top than the T67 from what I can gather.
RB25DET gearbox shifter circlips can suck my nuts too.
Missing some skin from that ordeal :(
Look to have the water leaks under control now :)
Found the casting on the water tube which sits under the RB26 intake was fouling on the adapter plate.
This was just enough to make the water galleries leak, so I ground off some of the casting dags.
I also got a HKS metal gasket set to ensure the seal is more robust.
Did a thing as well to replace my Defi Link Screen and Blitz ID3 Boost Gauge.
This will allow me to swap to Bosch Oil Temp & Pressure and Fuel Pressure Sensors.
Edited by Wheezy
  • Like 3
Got anymore detail on that turbo? What spec impellers and turbine housing?
I ran a Kinugawa one with 11 blade turbine, 12cm T3 single scroll for several seasons. Was very good performer at the price point, only mistake I made was to spec a more compact comp housing with 3 inch inlet. My car was intentionally kept at modest boost and 375rwhp for track, but a short dyno test  with more boost showed 460rwhp on 98 petrol was no problem.  The bigger comp cover would have been a better choice if I wanted/needed to pursue bigger hp than that.
See attached.
Hoping for 600rwhp on it maxed out.
That's with 1.9bar of boost
@Dale FZ1FZ1 I think the 25G is a 12 blade. There is a thread from years ago in forced induction which may have the specifics.
I recall counting the blades when I got the turbo a year or so ago. Could be wrong however.
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
