They had sent me a walkaround of the car showing all the areas where the clearcoat was peeling and offered to repaint the car if I wanted so I had them go ahead and repaint the car A54 to be a brighter color than the AH3.
Once the car was in my hands, I needed to get rid of those dated RPF1's.  I know they are a favorite of most of the car community but they just aren't my taste.  Went with a set of 18x9 +30 Aodhan LS007's on 245/35 BF Goodrich G-Force T/A KDW's.  I love the aggressive tread pattern.
  • 3 weeks later...
6 hours ago, KiwiRS4T said:
Good work. Have you considered replacing the heater core while the dash is out!
I actually was thinking of replacing all of the heat and ac components that I can come across to make sure its good for another 25 years!
9 hours ago, ActionDan said:
Is that Active Red?
Hahaha!  Paint code is A54.  I'm sure it goes by a few different names, but wanted to keep it a Nissan color.  I wasn't a fan of the AH3.  Too dark and gloomy for me.
18 minutes ago, ActionDan said:
Similar but no, Nissan had quite a few reds through the models. This looks good.
Why are you pulling it down if it was already resprayed?
I like your wheels better than the RPFs
because when it was painted, they didnt do the engine bay so it didnt match.  and then some quarter panel rust was coming back so I decided to get the overfenders to get rid of it...and then went wider front fenders, hood, bumper, and spoiler...so it all just needed to get done since I was pulling the motor too.  I basically want it to be pretty much a brand new car when its back together and last another 25 years lol.
9 minutes ago, ActionDan said:
Nice, it will look great when it's done.
Plans for the engine?
full rebuild to just refresh everything and then bolt on some good stuff.  kinugawa bolt on turbo.  fmic.  r35 coils, r35 injectors, emu black ecu, front facing intake w/ ls drive by wire throttle body, 350z drive by wire pedal, tomei cams and adjustable gears.  all the basics.  I'm also completely removing hicas with an s13 subframe and all of gktech's adjustable arms, and added air ride.
Should be a tidy little rig.
Could I possibly encourage you to go something better than Kinugawa...
RB20 needs all the help it can get with response. A Twin Scroll GTX would do nicely without breaking the bank.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
