Taking the 350Z to Challenge Bathurst , 20 minute sessions, and this time rather than run true semi's I've decided to try something that will still work if it's wet. After a lot of research the Falken Azenis RT615+ seems to be one of the best but it appears that Falken don't bring in the bigger sizes in 18" WTF. Federal  595 RSRRS-RR are the current version of the venerable 595  but I have no idea where they are in the grip heirarchy now. Anyone with recent experience with these or others?  If there is interest I'll give feed back.
Edited by 260DET
https://www.sau.com.au/forums/topic/478416-200-wear-semi-slicks/
I've run Hankook RS-3 with a 200TW on my old S15... running 2000rwkws
I was finding them relatively good but I wasn't all out for a 15 minute session, typically I would do a cool down lap per session (2.30 laps)...
  • Like 1
37 minutes ago, 260DET said:
Present short list is Hankook Ventus RS4, Bridgestone Potenza RE71R and Falken Azenis RT615K+. Bridgy's are a bit on the expensive side.
I wouldn't call the RS4 a semi, good dry street tyre yes, semi no.
In saying that I've used them on the track with my old 33 and MX5, IIRC they preformed good on the 1000kg MX5, and OK on the 1550kg 33.
Opinions may vary
The Falkens are only available up to 265 wide, with 10 and 9.5" rims wider would be better for my heavy biatch. Any alternative suggestions for Bathurst?
Nengun list 18" A050's at ~ $1000 EACH and no wider than 265 LOL.
Do they HAVE to be 200TW? If not, Nankang AR1. Failing that, any of the 200TW options are okay. I personally think the RS4's are the best bet for value right now.
Nitto do wider sizes than 265 (as do Hankook) if a 285 or 295 is more suitable those are other options. But I would say that if you really want 295 then you may as well get something better than 200TW to do it with.
Yeah, Albion Motorsport have quoted $619 each for 265/35/18's which suit my 9.5 and 10" rims. Will check with Dunlop to see what they have but this time I want a fun tyre with plenty of feedback. Will have a look at the RS4's.
  • 1 year later...
  • 3 weeks later...
obviously nothing better... I'm damn sure there is alot better I have yet to try, just giving some user experience feedback to the oP :). I should've pointed out my RSRs are softer ones. after reading this thread i cannot seem to find replacements for them them stocked anywhere.. did they stop making them? there only seems to be like 200tw or there abouts. where is the 93W-140s?
Edited by SilverECR33
correction
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
