Hello guys, first of all, thank you for stopping by and giving this a view!
Okay so, the car ran perfectly after the tune but about 3 days later under full throttle, when it reaches about 6-8k it will start to backfiire about 2-4 pops.
Things I've done to try to fix the problem:
  • Changed spark plugs and gaped to the tuners specification of .02
  • Changed fuel filter
Things the car has done to it that relates:
  • 550 Walbro (tuned with the car)
  • Fuel pressure regulator
When I changed the spark plugs they all looked exactly the same, which makes me believe that the coils are working fine. But the plugs did look fouled as shown in the picture.
I also attached an image showing my gap that was perfectly at .02 without damaging the tip. My fuel pressure is about 38psi on idle.
Any help would be greatly appreciated!! Thank you!
8 hours ago, admS15 said:
0.02? Wow. As above get better coils.
I’m running stock rb25det coils. They need to be more powerful? It was running fine with them on the dyno. My fuel/air on idle is 13.7 and under load it’s 14-15psi
8 hours ago, mlr said:
I had to google, that's only 0.5mm, wow
How much boost you running? What coils you got?
I’m running 19psi of boost at the moment with stock rb25det coils.
If the coils are 20 years old, they're at the end of their life. Replace with either fresh oem or splitfire coils. Dont bother with any of the other coloured ones. If you can borrow a set of known working coils to verify first, that would be ideal.
It’s making 425ho. Since everyone is telling me to change the coils then it has to mean something! Okay, I’ll give that a shot and check in with you guys again!
Thank you all!
Eric
The official gap is 1.1mm but people often gap down to 0.8mm or .63 if coils are weak. If your tuner is telling you to gap down to 0.5mm he knows you have a problem. What plugs are you using?
Did you get that fuel air the right way round? Idle should be around 14.7 and under load around 12
You've either got a dodgy tuner or you have other problems with your car.
Idle is currently 13.6 and load is 14-15. The spark plugs I’m running are NGK 4644. My technician recommended .023 and my tuner .02. I’m running stock coils but will soon install the splitfire. Do you think that will fix my air/fuel and high RPM backfire? My tuner will verify the tune tomorrow, hopefully.
No
Yes you need new coils but also a new mechanic and tuner by the look of things.
Do you have any dyno charts you can put up? Particularly interested in the afrs!
BTW how is your car being tuned (what kind of ECU do you have)?
7 minutes ago, KiwiRS4T said:
No
I purchased the coil packs, they were $485 USD! Ouch!
I’m running a link (AEM) ecu so my tuner can tune the car wirelessly without it being there. I shot him a text earlier today so I’m waiting for him to get back at me.
Unfortunately, I don’t have any dyno sheets. If the car keeps running like hell after the new coil packs, new spark plugs at .02, and after my tuner verifies my numbers look okay, I think my problem will lay something in the fuel system like a fuel controller or something, right?
1 hour ago, Ben C34 said:
What? Why is it running leaner under load than idle?
Why running 13.5 at idle.?
The difference of 3 thou gap won't fix anything.
He might not be able to get a nice idle at 14.7 if he is using large old school injectors. Cruising around at 14.7 would be easier to tune as the injectors are out of the low slope range.
Eric, what injectors are you running?
  • Like 1
So your car is not sitting on a dyno? The tuner is just playing with the maps? Do not gap your new plugs at .02 go to 32 thou (.8mm or .032 in)
The fuel controller is the ecu so if you reckon the pump and fpr are fine that just leaves the injectors so as Murray says what kind are they and could they need cleaning and testing?
Do you have any idea what the duty cycle is on the injectors? I still think your tuner does not know what he is doing.
  • Like 1
+1 on resetting your plug gap to 0.8mm/0.032"......the ability of your spark plug providing any sort of meaningful spark at 0.02" would be a real struggle esp. at higher revs.
I’m running deatschwerks 740cc fuel injectors. Should I be driving the car at all? I’ve been staying out of boost.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
