Hey All
I can't seem to find this problem anywhere. After highway driving for 20 mins or so and leaving it in 5th I hear a slight whine from diff at 80kph. I have changed the diff oil to nulon 75w90 correct spec and it made absolutely no difference.
Any idea what the problem is? And no vibration at all.
Some say additives work some say they don't but I don't want to fork out for the redline stuff for it not yo fix anything.
Ideas pls?
https://www.sau.com.au/forums/topic/478849-r32-gtst-diff-whine-after-warmed-up/
On 10/4/2019 at 11:10 PM, Dil-Dog said:
Time to weld it ?
Welding won't fix it, it will be due to pinion bearing wear and the pinion/ring gear mesh is slightly off causing it whine.
Needs rebuild to fix, and depending on how long its been driven like this the pinion/ring gear might need to be relapped.
-Blake.
  • Like 1
My $0.02.
In other words, crown wheel and pinion is rooted. Maybe not totally rooted but if it's making noises the damage has been done and they're on the way out. Need new MATCHED set, installed and shimmed correctly for correct gear backlash. There is no magic fix for worn diffs and no additive is going to fix it, no not even that Redline crap everyone raves about.
I stuffed mine that bad in one of my GTRs in the front (where people usually run lighter oil) that the crown wheel and pinion gears were actually razor sharp to the touch, which is a lot of wear if your familiar with crown and pinion gears. It made all sorts crazy noises under load, and why your noise is appearing once the diff oil is hot and thinner in your differential. I will never run ANYTHING other than 75w - 140 in any GTR diff front or rear again after that. After 19 years of GTR ownership anyone who runs stuff like 75w - 90 in any GTR diff front or rear is asking for trouble. I know it's a gtst but same thing basically. Anyone tells you to run 75w - 90 is a dickhead and asking for a diff rebuild, unless changed very regularly and / or has very little power.
It's all about protecting the crown wheel and pinion and the heavy stuff does the job, especially when most people don't drop their diff oil that often.
Motul comp gear 75w - 140 or Castrol Syntrax 80w - 140 (used to be SAF-XA) or you may as well put water in your diff.
Both the Castrol and Motul is generally around the $30 - $45 a litre range. Most other reputable oil companies have diff oil in that range too, Castrol and Motul just seem to be the top pick and Castrol is readily available. Castrol used to be the most recommended by companies like Holinger and Albins until the Motul stuff came along.
On 10/7/2019 at 11:46 AM, LINK17 said:
I think this is the problem, I checked the diff oil and it's 75w90, thanks for the great advice.
I love the motul stuff but can't find where to buy except stupid prices online?
I use the Motul or Nismo oil. Its expensive but you don't need much and have you priced a diff rebuild?
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
