4 minutes ago, jordanperrett said:
just wanting to know what everyone does to get a little more horsepower to the wheels.
Hi, good question.
You want " a little more horsepower to the wheels" 'so you need to reduce friction and inertia losses from the drive line.
Carbon fibre tailshaft, thinner diff and gearbox oil come to mind.
But it's an odd question, most people want to make more power in general, and wouldn't you believe it, in the last 20 years some people have even done so with the particular car you own!
what are the chances of that!
  • Haha 1
Increase boost a fraction with a cheap manual boost controller. Your next question - google it as this has been done hundreds or thousands of times on a car just like yours.
If you wanna stay relatively stock... (not opening anything or changing turbo)
A nice Clutch will help but 100% a nice light weight flywheel is a great bang for buck upgrade and will make a very noticeable improvement. but if you have a r34 GTT make sure you get a pull type clutch as that is what you will need. I have a SPEC stage 3 , 6 puck and SPEC light weight flywheel
You can also safely crank up the boost 2 or 3 pounds from stock with out having to worry too much.
You can also invest in some high quality lightweight rims and good tires, it actually makes a world of difference. you wont believe how extremely heavy shit replica wheels are and how it affects performance.
A nice supporting mod as well is a front mount intercooler, you can get decent kit from CX racing if you are on a budget.
Idk where you live and your laws but my 34 is straight piped, only a single muffler tip.
bro .... we can go on and on and on for hours, you gotta set a power goal and then see what you need to achieve it safely. for example if you want 450 hp, you will need X-cc injectors X-lph fuel pump X-size turbo and anything past 15-18 psi you will surely be reaching the limits of your Air Flow Meter and then at this point you gotta get a nice Stand alone Aftermarket ECU.
Edited by Dil-Dog
Buy a BMW M4, then MHD OTS reflash.
OR you could do what @Kinkstaah did to get a little more horsepower
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
