Finally got around to putting some car builders under bonnet stuff on, basically to camoflauge the chop chop a bit
I do need to replace the windscreen squirter hoses though as they have hardened up
Before
After
Fully stock now.....
  • Like 5
Consumers will consume, I pulled the pin on something for the Honda I said I didn't need, but meh, a PLM header, comes with a decat
The decat pipe will get the cat chopped into it
This basically optimises the exhaust now for NA duties
PLM-PCD-14-2T_15d4132e-05c4-4755-a99e-ce8cb2504c96.thumb.jpg.7dc660223f0ee35550e57e627e38d078.jpg
Express shipping so should be here in under a week
But probably not as it is coming via Australia Post from QLD, so could take a month
But apart from this, the Honda is staying stock....
  • Haha 1
So when fitting a g35 1050 and quaife sequential??
The bogan cruise ship going to modded any further?
Keep an eye on here for drag and drive event
https://www.facebook.com/groups/314009295848803/?hoisted_section_header_type=recently_seen&multi_permalinks=1104579606791764
  • Like 1
I'm happy how Bogan Cruise Ship is, so just maintenance and the assumed broken bits now and then
As for the Honda, if, when, the clutch goes it might get a LSD (while we're in there), apart from that it will remain "stock"
I keep trying to spot them when driving around, I think "there's one", but nope, they keep turning out to be Toyota Camry's 🫣
  • Haha 1
Big difference between the stock pressed and welded steel header pipe and the cast aftermarket one in relation to smooth flow
Plus the OEM header isn't matched to the head or gasket, whereas the aftermarket one matches the gasket and head
  • Like 1
Took the Bogan Cruise Ship to Goulburn to visit the daughter for 2nd breakfast and lunch, car was a pleasure cruising on the Hwy
The kid has grown up and is adulting like a boss
I miss my "little bunny rabbit" who only had time for her dad, now it's all "I have to go to work now dad" (NSW police).... proud dad is proud
I believe my parenting superpower was letting her watch me do dumb shit, and her learning from that of what not to do
In saying that, her Xmas present, that she asked for, was a cat back for her new Kia Cerato GT hatch, that did put a smile on her face when she took it for a drive after we fitted it
  • Like 2
Gave the Bogan Cruise Ship some love IRT paint
As there is no one really at work I had easy access to the wash bay, and undercover parking
1. Truck wash and hot water pressure washer to clean off most the old wax and sealer
2. Then some Chemical Guys clean slate to clean off what the truck wash and hot water pressure washer missed
3. Then 2 coats of Autoglym ceramic coating
I'll give it a day for the ceramic to cure, then hard wax it
Whilst the ceramic leaves it nice and shiny, I find a good wax will give it a deeper look to the paint, I also find the wax also protects the ceramic coating as a sacrificial layer
I'm basically preparing it for all the ash from the bushfires that will probably happen over the next month or so, and the hot water pressure washer at work makes short work of removing old wax when required (every couple of months)
As for the Honda, I finished painting the stock rims, they had some hectic scratches on them, but, am I happy with how they turned out, not really, but, they are much better than they were
Also, the new header and front pipe on the Honda is all V-Tec YO buzz box noises now when it gets given the beans, it is though surprisingly  quiet still when cruising around, whilst the Honda ain't fast, it is fun as a fuel efficient daily hack
  • Like 2
Major issues apparently with the noises the Honda makes now, Jackie has decided that the Honda is to "buzzy" when she is giving it the beans heading to the shops (the Honda is like the town bike for the family, everyone takes it for a ride) so I have a incoming resonator to keep the Minister of War and Finances happy
From the Google's the Vibrant 1140 will slip over the stock pipe for a easy fit, will knock out most of the buzz, and there is adequate room for it in the OEM midpipe without any clearance issues with the floor or ground clearance
I liked the bit of buzz at higher rpm as I felt it suited the Honda 4 cylinder V-Tec YO sound, but, you got to keep the better half "reasonably" happy I suppose
It gets its tune early Feb when Chongie heads down from QLD
56 minutes ago, Kinkstaah said:
K20 > MX5 BP1.8/LS1/RB
Logical fallacy cannot be processed. There is no world in which a 4 cyl engine sounds better than a straight 6. Especially one that sounds like an RB.
I mean, I had an ALFA 2L, with better carbies, ram tubes and sock filters and a great exhaust and I thought it sounded awesome. Which it did. For a 4 cyl. All borty. But it was nothing compared to 7500rpm in the Skyline.
I see your straight 6 RB and raise a 4AGE 20v with ITB reving over 10k rpm
Took the Cruise Ship for a cruise on Sunday, all was well until I headed down Bulli pass, brake fad was was interesting to say the least, I made it down without incident, but, the front right disc was blue/black and the caliper was smoking like a champion
After letting the brakes cool down we "gingerly" headed home at a extremely leisurely pace avoiding hills, luckily were at the bottom of the mountain and the brakes regained some bite for the plod home
At home I jacked up to find a seized front left caliper, the pistons are FUBAR from rust and the seals are also questionable
So, as I do, it is time to use my typical approach to things
I've ordered new:
Front and rear calipers (OEM)
Front and rear discs and pads (DBA street series), which by good chance were currently on special at SCA
And also new some new OEM front wheel bearing assemblies...... #while were in there..... (I'm assuming the front wheel bearing didn't like being at 11ty million degrees, and for a couple of hundred to replace it is a no-brainer, good thing the Commodore parts are cheap as chips to replace, and plentiful)
The Commodore has now been put to bed until all the bits and pieces arrive
  • Like 1
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
