So I'm looking at switching up my Intake setup due to an aftermarket turbo manifold.
Here are my specs before you tell me to spend my money elsewhere or to buy a 25 Yada Yada:
Hybrid Performance Turbo Manifold
GCG high flowed RB25 turbo
GTR Injectors (444cc I believe)
Z32 AFM
Nistune
So, the problem I face is with the standard J Pipe, the exhaust manifold is about an inch from the J Pipe elbow (refer to picture) and this causes concern for Intake Temps.
So instead of heat wrapping and shielding and all that, a buddy has a full RB26 intake setup that he said he'd give me if I want it. My main question is if I buy this OtakuGarage adapter plate, what issues will I face?
My thinking is that it'll make the intercooler piping shorter, and not run over the exhaust which could heat up my Intake Temps.
I'm looking for answers and solutions, not hate on RB20s. Thanks in advance!
https://www.sau.com.au/forums/topic/480130-26-intake-on-a-20-read-first/
How much money will you have to spend on the 26 intake (throttle shaft sealing, throttle plate sealing, etc, gaskets, coolant & air hoses, etc) to make it workable?
I thought about putting a 26 intake onto my RB20 20 years ago, and realised that it was a waste of time and money.
I'd just throw some ACL heat shield at this problem.
Yes, I've got some DEI heatsheilding stuff in mind, and wondered whether this idea would be better in the long run.
As for seals and everything, the cost of that shouldn't be too much
It was tried years ago on an rb20 and because of the short intake runners it made the poor low down torque even worse.
a better and cheaper idea would be to remove the factory L pipe and fabricate a J shaped pipe that doesn’t cross the exhaust side
Pros - engine bay looks cool.
Cons - eliminating long runner inlet costs torque. (very bad on a torqueless RB20)
Outcome - any perceived gains in improved "response" are swamped by the loss of torque that the factory gained through empirical R&D.
Suggest - run heat shielding, drive and be happy with turbo + tune.
I think you missed the point. Do you know how loose and sloppy these shitty old throttle bodies get after a gazzillion years of opening and closing? and how much work people have to put into making them good again?
I'm talking work, when I say "sealing". I'm not talking just the cost of actual seals.
And when I was talking about hoses and such, you do realise that there is very little from the RB20's collection of vacuum and water hoses that you can use, and that using the shitty old 26 gear that's been lying around dry in a shed for years is probably not the greatest idea, unless you like taking al that shit back off in a few months to fixed all the cracked and or burst hoses?
Perfect example of using a short runner manifold vs standard. The only thing I would use is the plazmaman plenum which bolts to factory runners.
1 hour ago, kye32gtst said:
Thank you for everyone's input, guess I'll save the 1000 for the Plazmaman intake, I'll just hope that cylinders 5-6 don't get too unhappy. Cheers
Save a $1000 and don't buy the Plazaman intake either...get a Hypergear turbo instead.
You have read that I've got a High Flowed 25 turbo right? Capable of 25 psi and 400hp. I'm looking for intake solutions, not trying to fix an issue by chucking a bigger turbo at it.
Wrap the manifold (or, even better, ceramic coat it). Place a layer of heat shield material BETWEEN the manifold and the intake pipe. Not touching either. Mounted with little brackets so something.
Presto, no heat transfer worth worrying about. That would even be true even without doing anything to the manifold, just the heat shield, as I said in my first reply.
Okay sweet, I was just concerned about the heat transfer part. Thanks for clearing that up
Yep I saw that - I had one of those and just made 273KW on a 25 so I don't think you'll see 400hp but happy to see you prove me wrong.
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
