Hi!
I have had the pleasure of having my high pressure line on my power steering start leeking.
Tried to so a quick fix to no help, and since stagea parts arent easy to come by where i live, i was wondering if anyone have swapped out the oem with AN connections and hose?
8 hours ago, KiwiRS4T said:
What's a servo?
Supose to be power stearing, but i forgot that power stearing was the word when i wrote it, and servo is what we use to call it and sounded rigth in my head, gonna try to get the post fixed
If you don't have access to Nissan parts and can't wait to source them from Amayama  etc then a hose doctor (hyraulic hose repair) such as ENZED, Hydraulink (don't know what brands you have  where you are) should be able to make one for you.
  • Thanks 1
The w8 i can handle, the 350$ + shipping +25%toll i can not ?
Therfor i wonderd if anyonr had mad eout of AN so i coud just make it myself ?
How could you make it out of AN fittings when there are not AN fitting on the PS pump or the rack? You have whatever fittings Nissan put on there. But these will just be a hydraulic fitting of one sort or another, so if you took the PS line into a hydraulic hose doctor place, they should be able to knock something up.
Ther is adapter that can be used mostly, on the pump side is a normal banjo so not hard to find
On the rack side is a bit wors but shoud be posible if i can figure out the siced :)
6 hours ago, WR33KD said:
Im changing all my lines to AN high and low pressure side. It can be done
Cous you tell me witch firings are in the rack? Or at least what treada and atuff so i can irder some and try ?
Do you alsoe kbow if the sensor conekted in the presur eline is any inportant? ?
You need to rack fittings that go to an6 and one pump fitting that goes to an6 then an8 from pump to reservior. Hardest part it making sure your long enough so a lot of measuring
AN hose and fittings should not be used for hydraulic applications like power steering. Get a proper hydraulic hose made up - it will probably cost less than trying to do it with AN hose and fittings.
How so? They are strong and can withstand hige presure, as long as you buy the corekt hose :)
The price wil probebly be more expensive if ingo to somone ro make ir due to wher i live, alsow they most likly wont do it because it is car related and stearing related.
First world country that is smaller than most states in Australia. Just drive to a place that can build you a line.
I can think of 15 places within a 1hr drive of where I live that will build a power steering line for me. All of them industrial hydraulic places. You should tell your weenie TUV koolaid drinking Euro regulators to shut up and just let people make a hydraulic hose.
  • Haha 1
More expensive than what? Mobile hydraulic hose doctors make lines for $million machinery including huge excavators and small forklifts. They make brake parts, steering parts and more for all kinds of vehicles. Do you know how much pressure your steering system can experience momentarily? A professional is going to do a better job than you can  and has the gear to do it.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
