13 hours ago, robbo_rb180 said:
5000rpm is good along with 70% TPS. Could wire a pressure sensor in and track pressures to find where system is efficient too and switch the condenser fan as needed.
I am interested in this kit, the compressor and condenser efficentcy will be a massive improvement
https://frenchysperformancegarage.com/collections/cooling-and-air-conditioning/products/fpg-nissan-skyline-r32-a-c-air-conditioning-replacement-kit-r134a-fpg-039
Got any good hints/tips for an AC system to run from a battery.
To be installed into a custom back on a dual cab ute. Will be for travelling with multiple dogs in, and when out at trials and work times. So need to keep it cold to keep them comfortable. Will be ran on big lithium batteries.
probably something designed for a sleeper cab or if super budget a window box cooler and an inverter setup.
9 hours ago, admS15 said:
Passenger in the first pic is lovin it. Car looks the goods.
I can't keep her out of the car when we can run passengers.
8 hours ago, Duncan said:
Looks nicely sorted for grip :thumbsup:
Yeah but more is always better.
This won't be a cheap setup. Will be spending a lot to build it correctly, and with fail safes in it. Not putting my children at risk.
Had just been searching online and not finding anything that looked proper useful. Looking for an electric compressor, and then the other bits and pieces that I can lay out where I need.
  • Like 2
Thank you for mentioning that! Feeling relieved now because I was getting a bit concerned about you leaving your dogs in the heat in the car with a potentially dodgy setup. Not sure if I could live with myself if something like that went wrong :)
https://www.tcboxes.com.au/collections/dog-boxes/products/800mm-dog-box-alloy
These are like what our "working" dogs at work roll in
Relying on aircon is relying on something that may fail
Some ventilation, shade and water will keep them happy, you can also get tarp covers for cold and inclement weather
Keeping it simple will keep them happy
  • Like 1
What kind of dogs are they?
All in one unit is definitely way to go. Designed for a certain area size and warranty. But just having moving air is good.
^^^This too, working with dogs overseas in summer time they acclimatised pretty well. Was a lot of very long "walks"  but any time could get them into a pmv for ac was good.
  • Like 1
Dog box like above won't be happening, it's entirely unsuitable for our situation.
It's 3x German Shepherd Dogs.
As I said, it'll be setup with failsafe redundancies for the whole thing.
But the vehicle could sit in the sun for quite a few hours, and then dog will be able to get out, and being able to run them on point is a major benefit over a dog that is already hot, and then gets out into a 35 degree day.
Will have ability for air flow (fanned, and vented for when moving), as well as fully insulated, major electronic backups on the system, and ability if need be for doors on it to auto open (without releasing pups) for air flow in event of internal temp increases.
Big issue is one of our boys is getting older and HATES the heat, and one of the others won't show signs of wearing out until he needs to be at the vets as he's about to die (never give up attitude), except he can get a bit of brain fade and turn off his listening ears. So keeping him cool when it's a stupid hot day up here is pretty paramount for what he does.
The sorting out an easy to install AC is the only difficult part for me at the moment. Though may if need be look to re-engineer an AC from an EV.
You can get a caravan aircon unit and aux batteries that run on 12v images.jpeg-62.thumb.jpg.485f5a9234dd1db9972d825f1d2487cb.jpg
  • 1 month later...
Been slow doing updates here but already done a few events this year and upgrades seem to be happening as parts needed.
So to start off the year I went over the car with a thorough bolt check, grease bolts in bushes, ziptied bit up and redid all the fluids. Found one of the caliper bolts had decided to back so put a spanner to it and .......it wasn't moving. Some patience with wd40, 1/4 drive impact socket and a rattle gun had it out, The thread in the caliper was not bad and a tap cleaned out the debirs. New bolts with a washer and no problems since. Got a new windscreen fitted as old one had a lot of chips and developed a crack last time out. Fresh screen was sourced and fitted locally.
Next up were new tyres the old A050 were well worn and 2 were almost slicks. I had a choice either spend the dollars and go another set or try the Nankang CR-S. I have been part of the testing of the CR-S so I know the Pro's and Con's of both tyres and with the aim of focusing on time attack I went with the Nankang CR-S, having a hook up for them also helps. At the same time I got another wheel alignment.
With all this done I headed out to Lakeside Park for a sprint session with a few of the Skid Control crew to pretty much go get that monkey off my back after my last visit on the whole track..........
Weather was looking not great through out the morning then the organisers thought it would be great to let people take passengers at 70% pace on a wet circuit, one written off 2023 BRZ and damaged BMW later caused a hold up so lots of waiting.
Finally got out on track and scrubbed in the tyres for 2 laps then had a go at a fast lap. I think I did a 62 with a heap of traffic, which isn't slow but isn't fast. Tyres were great and I was feeling pretty good after that. Headed back out for  next session knowing if there was no traffic I could go a second quicker.
Did a decent warm up lap then went for it, seeing green on the racechrono I kept pushing and was up a lot by Hungry corner. Coming down the hill then across the line I saw green and a 59.89. Finished up the session and cruised back in to the pits to one of my mate stopping me in the pit lane and told me the official time of a 59.0!!!!!
https://www.facebook.com/100000026398820/videos/568597401864367/
excuse the belts in front of the camera
In car of the lap
https://www.facebook.com/100000026398820/videos/3462819007280321/
So after that I decided it was time for new brake rotors and pads. I had been planning to get Endless ME20 but non in the country or Japan until at least end of May so went with Project Mu RC09 pads and the usual DBA4000 rotors. Easy fit up and done in a few hours.
 330022665_741721684233412_8125712691079930428_n.thumb.jpg.6f44778684cd08c7fac95d3bf73bc61f.jpg
333088642_915090692973331_4228050232935963984_n.thumb.jpg.582f948a910b22f166c16726406ddec6.jpg
332765911_168134322654803_5996671588456834582_n.thumb.jpg.d7b4e77dc9bc4e7f9fbdc16a782f75ec.jpg
329936790_1363245721136012_2057013924310914946_n.thumb.jpg.4fa8cf6e2912b3b3bd6b22db1faa84b3.jpg
Wheels got a good scrub too
328544223_3450656858589224_3063443846678765476_n.thumb.jpg.bfc0bac663429dfb5d81ab91dcaed43c.jpg
330081872_585638276765013_6438036760507797405_n.thumb.jpg.f8350c77bd4e6d30be17d20e4fb69276.jpg
332926166_1357018558415367_4521531789479951980_n.thumb.jpg.cb2309f7ade2dc077d8fd00c4f2405af.jpg
327900784_1825645034480812_5401387747096776299_n.thumb.jpg.cbb68c02c2fb4aa14a61d7ecac587861.jpg
All this was in preparation for Time Attack round 1 at QR. the old brakes wouldn't last 1 session.
First session I used to bed in the brakes and get a feel for them, towards the end of the 5 laps I got a vibration through the steering and pulled of cooled it down with a few laps out back of pits. Car really need me to give it throttle to move too......... Got into pits and no visible signs.
Jacked it up and took off the wheels, deceided to crack the caliper bleed nipple and pressuirsed fluid came out so went and bled the system, brakes felt good, quick spanner check, refitted wheels and re torqued the nuts.
Session 2 got a good warm up lap in and went for it on the first lap but missed my brake marker then forgot to down shift to 4th quickly, slightly turned in late at turn 1 but was up on racechrono, turn 2 was good through dipper I was a bit late on brakes got the apex but didn't stay to the right enough for the left up hill managed to get the apex with a good exit. Down towards the next corner I nailed the braking and turnd in got the apex, then left into the final corner but turned in too early and ended up having to double apex but got on the power early enough. Crossed the line with a 57.29 on racechrono. Thought I would go for another fast lap, nailed turn 1 this time but all of a sudden got the shake in the steering again 😬
Pulled off the track layout so session wasn't held up.
Ended up with official time of 57.26 which I am happy with and qualified for Holy Grail lap time going sub 58.
Got back to pits with same issue. A few calls and messages to people and looks like return valve failed on the BMC, a GKTeck/Holfords one. Seems they don't like the heat.
As wel as the brakes the coils were getting hot causing a misfire too so pulled the pin on it.
The one proper lap I got
So already have bought genuine BM57, Taarks r35 coil kit and a Race Box Mini for better data.
Parts should turn up next week, get them fitted and then head back out for round 2 at Lakeside and better my PB there.
23rdFebTimeAttackDay2023-(4)-(ZF-9581-93600-1-001).thumb.jpg.8c4915bf686f1c9bce8fb07ba32c2794.jpg23rdFebTimeAttackDay2023-(458)-(ZF-9581-93600-1-002).thumb.jpg.57b05ae13333755178b9bed88816f7f4.jpg23rdFebTimeAttackDay2023-(658)-(ZF-9581-93600-1-003).thumb.jpg.2f4b38f54d31ac67d5f32e712718d731.jpg23rdFebTimeAttackDay2023-(661)-(ZF-9581-93600-1-004).thumb.jpg.2d8e7ff2c1d6f3b937b2c72ae5a2f6fb.jpg23rdFebTimeAttackDayPM2023-(742)-(ZF-9581-93600-1-005).thumb.jpg.383efb555b7a3e1cd1e256418677e5ed.jpg
  • Like 4
  • 1 month later...
Picking up where I left off.
As usual Taarks/efi solutions delivered quickly and got staright into fitting the coil kit. Pretty easy install and replaced the spark plugs while I was there. The kit comes with new plug and pins for the cols but after removing the splitfire kit I didn't have a loom so took the oppotunity to make new one. Bought tefzel wire from local supplier and had some raychem heat shrink from previous looms. Tried a different method with measuring and planning and it turned out pretty good.
With that fitted, changed dwell settings in the ecu and fired it up. Biggest thing is obvious with all the fuel being ignited is it now was running leaner so had to add fuel everywhere. Biggest place was on boost with upto 15% fuel needing to be added in places.
Fitted the BM57 and bled the brakes with the help of a local mechanic. Brake pedal felt a lot better.
With all the work done headed back to Lakeside for Time Attack round 2. First session out car felt good on the 2 warm up laps so went for a fast lap, brakes were great at turn 2 and kept pushing through bus stop to hungry corner but at the top of eastern loop got a big vibration again so went straight into the pits. Car was also a not coming down in temp as quick either (normally 90-92 but 92-94 on a cooler day)so a few pit laps and straight back to normal.
Quick check of wheel nuts and suspension couldn't find anything so went back out for second session and did the 1 warm up and went for a fast lap. The lap was ok but lost time at the top of eastern loop with a slight correction. Ended the lap with 59.9 but decided on a second flyer but again towards middle of the lap got the vibration in the front again so pitted and a lap of pits to cool down. Parked it up and called it a day as I was instructing in the afternoon. After around a 30mins went to move the car and felt front left brake dragging.......
Here's the in car from the best lap of the day. The race box mini was great paired with RaceChrono to give me more accurate data. Got a few adjustments to make tyre pressure and suspension before next time at Lakeside as car feels unsettled through the Kink and Bus Stop.
Debated about how to fix the issue. Rebuild current calipers or fit the EVO brembo kit I have sitting on the shelf for the s15? Needed brake pads and rebuild kits for the EVO kit then would need another kit for the s15. With having no where to work on the still, went with a rebuild the current brakes. Found a local shop that was happy to help. After 2 days and a few $$$$ the shop had it all sorted. The Front calipers required seals and pistons were salvageable the rears though needed all new pistons with seals and front rotors were machined too. Now looking on all the track calendars to find a test/practice day to see how it goes before next time attack day. Looking at Morgan Park as haven't been there for over a year and a good variety of corners but also the cheapest as QR now requires Motorsport Australia licence for practice and sprints.
Hopefully thats the brake issues now sorted and can get back to driving it for a whole day.
  • Like 4
Interesting on the need to add more fuel, as it started running lean with better spark.
In my mind, having incomplete burn, means not all of the fuel has been burned, which means you'll have excess oxygen in the exhaust, and an O2 will read lean.
This is why misfires end up reading lean, even if it's from excess fuel.
I'm genuinely curious now as to why with better spark it's showing leaner every where, as I've always understood it to be the other way around.
I could see it getting a bit leaner as it's coming onto boost, as it might be coming on a bit earlier with a nicer more complete burn, but this would only show if the last coils were unable to do the job properly ever, and hence that section of map never got reached to be tuned, but across the board needing more has me baffled :S
As I said upto 15% in some spots but on average 5-6%.
The quality of the previous coils was questionable as plug gap was down to .6mm and would breakdown over 18psi or around 2 laps of QR. So now burning all the fuel injected. I am sure someone much smarter/experienced can explain it. @Dose Pipe Sutututu @Ben C34
I am wanting to get it back on a dyno but struggling to find a tuner I can trust and willing to work with me on setting up some other ecu functions.
Edited by robbo_rb180
That is a bit of a funny once, generally with misfires you will read lean as the oxygen in part of the mixture has not combusted.
The only plausible scenario I can think of is both fuel and ignition trims at play trying to keep the motor idling with the poor spark before. Potentially it may have been tuned to compensate for slight misfire at idle and now that the combustion is sex spec the idle closed loop strategy is pegged to add in more fuel but it's maxed out.
  • Like 1
  • Thanks 1
Guy across from my work races (just did 12hour and doing 6hour at Bathurst) uses PowerTorque in Brendale, and work has used another place in Seventeen Mile Rocks but I can't think of their name off the top of my head sorry.
Nekminit, O2 sensor has failed and new plugs end up fouled :P
  • Haha 2
Will look at it a bit more tomorrow. Idle has been good it needed a slight adjustment on fuel. Looking at a log it also was only making 14psi not the usual 16psi on gate pressure. So guessing they didn't tune that area too well........
Hopefully not but it would give me a chance to upgrade to a CAN lambda as still running it over a 0-5v ANVolt input. Lucky s15 has a haltech wb in it.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
