7 minutes ago, niZmO_Man said:
Where is it located? Maybe show a zoomed out picture? Follow the wires?
It's located under the steering wheel. I have uploaded a zoom out picture. Yeah i will just follow the wire. Do you think it could be adaptive Front-lighting System?
My BMW has a switch for realigning headlights according to load. Later Nissans had it also, is this the early version? Have you tried it out in the dark, point the car at a wall and see what the headlights do when you activate it.
  • Thanks 1
Oh my god !
"Wouldn't press it if i was you."
That's going against human nature !
Its in humanity's make up to press that button.
If there the was a big red button marked:-
"END OF THE WORLD BUTTON DO NOT PRESS"
Before you could turn your back . . . . . . someone would just to see what happens.
So, this thread was funnier to me until I picked up the Fuga today, and it had that button too.
Anyway, after some quality time with the paperwork (yes, an import that actually came with original papers!), it is a button related to the option ultrasonic alarm.  I also have an extra "security" led on top of the steering column.
So, turn the switch on, headlights to auto, lock car and walk away. Approach with key on you after dark, and an LED lights up the driver's door handle so you can find it and unlock it using the door button. 2021-02-20 20.23.30.jpg
  • Like 3
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
