Billet: 60 deg oil and water and send it
Other thing to consider is cast blocks other than potential cracking and splitting bores which is just a flip of a coin is keeping the head on. 11mm head studs vs 1/2" needed to keep a head on properly and not really enough material in the cast blocks to keep 1/2" safe n sound for too long
Btw talking consistant big power applications
Edited by bcozican
  • Like 1
  • 4 months later...
He’s using an aftermarket power steering pump on the car and I’m yet to see one that doesn’t have that issue, maybe he should have used an electric power steering pump because it also doesn’t allow him to fit the second fan supplied by hypertune
Man that engine surely copped damage from that.
It wasn't under power but it spun for ages on the run down, that can't have been healthy. Can't believe he just looked at the cam lobes and oil and was happy .
His theory of the belt could have gone any direction and not caused trouble makes no sense, it can't just shoot off and miss the oil pump belt, it can only possibly do what it did.
I was confused about that as well, watching and thinking “where else can it go?”
Billets are sick.
12 mins mine takes from dead cold to be able to drive.
Just start it and go back inside wash your face, brush your teeth, get ready and it'll be good to go.
Lighter, stronger, newer.
Anyone who says you can't drive it on the street is talking nonsense.
  • Like 1
2 hours ago, Duncan said:
....I understand the upsides, but most people would consider waiting 12 minutes to drive the car after starting it to be a drawback for daily driving....
Yeah I'm not leaving a car idling for 12 minutes before driving it, even if I did that regularly I would want the option to be able to count 10 seconds and put it in gear. I would be afraid to forget and immediately trash my engine in the process.
3 hours ago, Piggaz said:
Surely if someone can warrant a billet block, the idea of that car being a daily driver is long gone. It’s a toy that’s taken out when you want. It can still be a street car. 🤷‍♂️
Correct, its a 1000hp+ roll racing / weekender.
600hp stock bottom end different story.
But even with a cast, 4 digit power levels built motors, you would want to spend a similar amount of time to warm your car up and get it on temp.
  • Like 1
You’ll never build a car that makes enough power to out flow the stock injectors let alone need a block.
Like piggaz and usmair said, these are toys, they aren’t daily’s! We aren’t using them to take grandma to bingo! Having to warm an engine up that cost over 50k to build is a very small price to pay
  • Like 2
Sure, but at some point I'm going to be in the market for a block regardless and stuff like that will be a dealbreaker regardless of whether I spend 10k or 50k or 80k on the whole package.
12 hours ago, usmair said:
Billets are sick.
I don't think anyone says you can't drive it on street. It's HOW streetable and that is always going to come down to what a person wants and circumstances.
12min for me is a garage full of e85 fumes, or roller door up whilst drivers by gawk at my other cars.  Plus I have young kids which I am often escaping from whilst they sleep. Then the neighbors, one across the road has a lambo, who idles for 10min before driving, he's had the council called on him from other neighbors.
So if i  was living the dream on an acre property and separate shed from house, probably have a billet block already and cheerish the 12mins of listening to my car idle whilst my brain soaks some e85.
  • Like 1
1 hour ago, joshuaho96 said:
I've been told RBs snap cams and spin bearings if you look at them wrong so any day now I'm preparing for a big engine build.
There’s only one person that says they snap cams and he’s the biggest troll on YouTube, they won’t spin a bearing unless your tune is junk or you try and track it with a factory sump
But you would have the same issue with a prepped built cast block? Surely you would warm up anything making decent power to its operating temps before driving it.
Before going billet, I did the same with my cast Block and that took around 10mins anyway.
Billet has actually made the car quiter somehow as well.
lol, I've snapped a cam, but it did take a special oil problem (workshop removed the strainer on the oil pump AND broke the head off an internal bolt overtightening it, you'd never guess where it ended up)
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
