Sound deadening is nearly complete. I managed to use 3x sheets of Dynamat for each door. Lined the complete inner and outer skin.
I will be doing under the back seat and parcel tray next. Hopefully that reduces the fuel pump noise considerably..
Speakers amp and subs are next on the list for purchasing
  • Like 2
Minor update:
Fueling:
I have decided to add E85/100 into the mix for a bit more power, so I purchased an ethanol content sensor.
I have also never been happy with my fuel plumbing/filter arrangement, so I am going to purchase a nice IDF750 fuel filter like @Murray_Calavera. Once it’s all here I will work out how to package it all neatly so it’s not that visible in the engine bay.
ECU:
Haltech have released new firmware for the Elite ECU and they have a new MAP prediction for tuning idle @Dose Pipe Sutututu not sure if I explained that right? Anyway, idle is now amazing and so smooth.
Throttle blip is now 95% there! I was driving round with the laptop this morning doing some tuning (keyboard mashing more like it) to figure some things out.
  • Like 3
Nice!
Looks like it works well, Andy from Haltech must have pushed for that. It allows compensation for when port velocity is so low fuel that is sprayed is turned into a fuel film.
I think it's called x-tau in other ECU
3 hours ago, Dose Pipe Sutututu said:
Nice!
Definitely better than the classic one.
i have also been toying with rotational idle (for wank factor) and launch control. Any tips for launch control ie. Ignition v injector cut etc?
If you want good brap idle, just have VCT enabled from 700rpm onwards and lower the idle timing in your zero demand table. I have it bouncing between 20 and 8 degrees LOL.
In terms of launch, I really haven't dialled it in as I just use the rolling anti lag switch for launch. That blankets retards 18° of timing and with ignition and fuel cut 100rpm over target. Gives me a little over 1bar of boost at 4500rpm or about 1.3bar at 5000rpm on a roll. Good for those cruise days at SMSP, and shooting flames lol.
  • Like 1
Dumb question…How can you change vct switching points with a keypad button?
I don't think you can easily, unless you get creative and set up a Generic output condition to override it.
I just have mine turn from 50°C onwards, car struggles to idle with it on when it's cold lol.
  • Like 1
So the quest for “comfort” continues…
The cabin always smells like fumes… I have a feeling that this is due to the VTA catch can setup I have (not a legality issue NZ), as the ATP can puts it right against the firewall, right next to where the HVAC draws air from (well I think anyway).
I have removed the charcoal canister (not legally required to my knowledge) and cut the lines under the car, which may also be contributing?
I have noticed that ATPerformance do a re-circ version of their catch can, so I will get that and hopefully that helps.
  • Like 1
put a small valve there, something that cracks after 0.1bar of pressure, if not you'll always smell fuel as the fuel tank breathes.
I have a one way valve, that cracks open at 0.1bar, some eBay junk. Stops the smell in the garage.
  • Like 1
Dose and Duncan, do you guys ever have issues where that valve has vented during a warm day, and then at night the tank has cooled and contracted?
Issues I could imagine might be the old fuel cap hard to get off as a main thought you could see.
My understanding is the fuel cap is sealed, or is it meant to vent and allow air into the tank to stop vacuum situations?
Yeah fuel caps allow air in when the tank is under vacuum, otherwise you create a big vacuum as the fuel gets used. Also, as Dose said any fuel vent should have a little spring pressure in it, you are meant to get that pshft when you open the fuel cap on a properly working system
  • Like 1
Old school fuel caps do I fact seal the fuel filler neck, however there's a vent elsewhere.
As of the 80s ish fuel caps started to incorporate 1x way valves to allow air in as Duncan has described.
  • Like 1
So I have managed to track down some finned RB covers for a reasonable-ish price (think half a crack rock instead of a full one).. These will be getting the same weld treatment, as there is breaks in the fins to fit the intake pipe over the top..
also on the weekend, I completed the sound deadening behind the back seat and on the parcel shelf. It’s times like these you realise how small cars of this era are..
While I was at it and the rear suspension top hats were accessible, I clicked the adjustable suspension to its softest….. but I still cringe when I see speed bumps in car parks..
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
