I wouldn't bother with the gtst actuator....when they were sitting around for nothing they were worth it, but now days because lots of people do the change they are getting expensive. just buy a manual boost controller "bleed valve" instead. they are more adjustable and start at about $40.
If I had a road gtst (and I did or about 8 years), I'd keep it under 200kw. Bit of boost, maybe a computer (nistune or powerfc, haltec is double the price for no benefit on a basic setup). Definitely shocks, springs and swaybars (guy sydneykid's kit). And then enjoy it.....spend any money you had left on entering motorkhanas and track days :)
  • Like 1
I'd dump the 12psi actuator in just for that little bit more of a gain. Hmmmm... Might just go for a nistune+tune and hope for a 210kw? Is that realistic?
Dont go the 12psi actuator unless you get an ecu. Or youll just end up in r&r
Theres always something you didnt think of or notice that needs fixing.
I think you should go the cheap option, you can always do more later.
One thing i noticed with having the bonnet open at the back, is that fumes come into the cabin.
The inlet for cabin air is in the plenum (under the front window) and because its a really bad idea to chop big holes in the firewall, its really the only place you can get fresh air into the cabin.
So i realize now, the vented bonnet i have is only good for racing, and i have to close the back of my bonnet, the best place to vent is in the front guards.
Like they said, cf isnt good in the sun, just go fibreglass, its not much heavier if at all. Many cf bits are just cf on the surface, fibreglass underneath.
Painting mirrors will cost NOTHING at all, i have plenty of black paint, and gold pearl powder if you want to play with that. Save it for the engine or computer.
And from my experience with my Nistune, i agree that more isnt better, smoother and more filled out is better.
Just remember, speed comes from the power delivered ALL through the rev range you use before changing gear. So a fatter curve is faster than a high peak.
  • Like 1
Didn't think about the air venting business into cabin... that's an interesting thought. I think I won't go for cosmetic but might chase 210kw or so.Nistune and tune or something. Not sure if I want to chase 250kw just yet... gah the choices!!
Jeremy I'll take you for a cruise soon in my 33. Maybe this week some time?
Sitting in the airport now
KEEN MARINE! ! ! !
Hmmm... maybe. Haven't been since Mik last entered.
Need New Camera Practise. :D
Do eet! :D
Oh, cams licence expired, cant afford racing at the moment anyway.
Still would like to go for a look. :thumbsup:
Yes! I would like to see the beast in real life ;)
Last month I was out there and it was a little wet. Turbo Ovlov almost went into the tyres at the first chicane :wacko:
Yeah they are small that's for sure. They wouldn't even be comfy for a medium build person.
Picked up the r33 from storage. Took roughly half hour to get started and then puffed black smoke for a while but now it's perfectly fine. Put a fresh tank of fuel in and took it for a good spin.
  • Like 1
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
