Ok.. Just wondering if people use either of these tyres on their dailys. I just wana eliminate 2nd gear wheelspin (and some of 1st), and I'm a happy fella. Dont care which tyre, hopefully they last more that 10-15,000kms too.
  • 3 weeks later...
KU36 going on the car today. It's no Rs3 but I couldn't turn down free replacement tyres.
Also if you're ever considering Goodyear Eagle F1 Asymmetric 2, don't. I have had two sets and both developed cracks in inner sidewalls in under 2 years and 20,000 kms.
tyres tyres...had Federal RSR 255/40/17 on the rear but 9000's ks and down to treadwear indicator...annoying thing is, HEAPS of trad left in side blocks, they're built very well for that. Looking at either Potenza Adrenalin RE003 or Dunlop Direzza DZ102, in a 235/45/17. Apparently that Dunlop tyre suits well in warm weather, might do well in the permanent summer of Qld?
  • Like 1
Im hearing a lot of good things about the AD08R. It is making quite intrigued to give it a go. But holy jesus its about $1800 for a set in my size.
Im sick of my RSR's and am tossing up between dunlop z2's, advans or a bridgestone potenza...
anyone tried any of these on a track?
I have the AD08Rs 265 35 18, they seem to hold power very well and unless you are trying really hard with AWD, no spin, chirp and off you go.
I got the Potenza RE003s around two months ago and they're fantastic, in the dry and in the rain. But then again the old set I had were so bad and worn I couldn't even make it up the driveway on a rainy day, so I'm experiencing a massive improvement with the Potenzas. If you're already used to having good tyres the Potenzas might not seem like much.
  • 4 weeks later...
so I got the RE003's....on for a week and not wowed by them, they're ok but seems sidewall is too soft, leaving them lacking in directional stability on the front when cornering hard. Will put a few more psi in them and see how that goes.
Had also used Nitto Invo's - bloody excellent, soooo much grip in the wet, I would have to ride the brakes HARD to get them to lock. Great in the dry too and very stable in cornering; got about 9000k's to them with about 25% tread left, at which point they had noticeably lost grip but still quite predictable, even though slidey.
Also used Michelin Pilot sport 3's, found them similar to the Invo's but just not quite as good IMO.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
