Thanks for feedback. How were the INVO's noise wise? I'm considering Michelin MC5 for my wagon as they are apparently quite.
very quiet.. very very quiet.. I dare say more quiet than the RE003 on the daily corolla.. but then again it's a corolla vs the r33.. the r33 has more sound deadening
ok after a drive in the mountains today I'm quite happy with the RE003's, with the tyre pressure now at 42psi (235/45/71 size). Didn't seem to overheat, gripped well and fairly progressive with the loss of traction. Not bad for cheap tyres.
RE003 is a street tyre. AD08R is a crossover track day tyre.
Understand that, just wondering if you were spending $200 for a street tyre which one would you buy . Probably get more Klms out of the RE003s
The AD08Rs seem a great all rounder, not sure how they will be once they are loosing some tread in the wet ??
ad08r are terrible in the wet, they are an extreme performance summer tyre so no surprise there
If you need traction in the wet, you need to find those with big water channels in the tread design (eagle F1, re003 comes to mind)
If you are not after out right grip, then go for re003s, but if you go to the track and want max grip, then ad08r/rs3s are the solution
  • Like 1
You haven't stated what your intended use is. AD08 for track days, RE003 for street driving. RE003 will last longer and have better wet grip. AD08 is one of the best dry grip street legal tyre you can buy. They're okay in the wet, better than what the tread pattern hints (on a WRX STi anyway), just take it easy.
At this time I just drive around country roads with plenty of fun sections.
I know reading and watching vids does not always tell the story, but it is better than nothing and was all I had to go off. It is hard getting past the manufacturers input ?
A lot of what I read before I bought them sort of backs up what you blokes have said about the wet, but I do not think they are that bad in the wet, BUT there is wet and there is WET! I think you are mainly talking about track work. I saw a couple of vids with these in the wet but they were from drivers not pushing it and a little weak on the KWs.
The best thing is, when it is raining that hard, I slow down a bit as there are too many dry days to enjoy.
But these tyres are great fun in the dry, like s**t to a blanket and unless you are smashing it , not bad in the wet :)
Which tyres? AD08R?
A mate of mine change the tyres on his then MY05 STi from the stock RE7-whatever to AD08 and said it was an improvement (softer sidewalls, heated up quicker, slightly better wet grip because it heated quicker). Was his daily until he sold it for an overseas trip.
after driving the mountain again today, as well as it being still damp in some sections, I further recommend the re003's. No issues with them at all today, very good in cornering, braking, wet weather. And this is impartial as I was prepared to not rate them at all in the initial 300k's. Will be interested now to see if there's much performance drop-off as they wear and what sort of life I will get out of them.
  • Like 1
can anyone recommend some budget friendly but decent tyres, rears around 245 - 255 (could go slightly bigger) for use on hill climbs. track only car
Needs to be grippy, 99% of the time in the dry so can afford shit wet weather tyres.
noise who cares
wear not to important either
track in generally slightly dusty
noise who cares
Rs3
noise who cares
Rs3
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
