apprently the 260rs brake pads are the same as the 33,34gtrs for the front and i would susprct th rers are the same. they share the same part numbers
of course they are :whistling: the brembos are r33 gtr items on 260rs's, and the r34 ones are identical but painted gold instead. so brake pads would be exactly the same :laugh:
beKW FLUIDS QIAE AHOULD I JUAT UAW dor 4 onwa or go for the dot 5?
Also i've heard that if we keep on changing different brand of brake fluid its not good for the rubber seals in the brake system is that true?
wtf does that say? :whistling:
one tip is to re-read your posts b4 u add them as typos just make it sooo hard to read
no offence it just shit me haha, take a look over it once u post to see if its readable :D
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd :laugh:
Edited by CruiseLiner
soz my son was playing with me and got distracted.
Anyway what i mean is brake fluids are there much difference between DOT 4& 5?
I've heard also about if we keep on switching brands when we change the brake fluids it will screw up the seals? Can anybody enlightened me please.
As far as i heard from Race brakes, they said it won't damage your seals. Also any brand of DOT4 is the same.
The difference between the DOT4 & DOT5 is the Boiling Temperature. DOT5.1 have a higher temperature rating and of course it's a higher quality brake fluid than DOT4.
wtf does that say? :(
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd ;)
f**kING GOLD!!!!
HHAHAHA
I had the same reaction. I started reading and thought, what the hell is he trying to say, LOL...
  • 2 months later...
  • 1 month later...
has anyone confirmed yet that the R33gts (DBA 4963) rotors bolt on to the s2 front with some outside diameter machining ???? the was some talk of them touching calipers, has anyone done this to their s2, or something different they can share.
What about R34 Gtt rotors and calipers on front and back, would this upset the brake bias significantly ? thanks
Edited by chook
  • 1 month later...
Hey huys im a little conf*cked.
i want new pads for the S1 had a look at that autospeedbits site and tried to work out from the selection list they have what i need for the front and back, but had no luck.
http://www.autospeedbits.com.au/resources/...BrakesList.html
here is my question:
are the pads on the front and rear the same as the r33gtst/gtr or the r32gtst/gtr.
sorry again but i have read this thread front to back and all i want is a descent set of pads.
thanks for any help in advance cheers again
Clint, I believe it's DB1250 for the front, and DB1144 for the rear, assuming you're still running the standard s1 brakes.
Unfortunately, they're only two-spot brakes on the front, and one-spots on the rear, as opposed to 4-spot F and 2-spot R on the R32 GT-R and GTSt, and R33 GTSt.
  • 1 month later...
So no one has found s2 stagea front pads yet,
I have spent heap of time trying to match up a set and the closest i came was a set of 'rdb 1439' they are slighltly longer and need some machining down to fit app 3mm per side.
The other day at work i was working on a 2005 subaru liberty gt i saw that the pad looked very familiar so i measured it ....157mm in length same as s2 stagea. So i will be checking this out shortly and hopfully it will put an end to all s2 stagea owners worries... :D
but if anyone else has a solution already please let us know...
and thanks
and thanks
ok it's not the 2005 subaru liberty gt but they are the closest fit as they are 157mm and only require alittle cutting and they will fit.
alternitively change to brembos GTR...or 4 piston GTS-T but yo may have to change the offset of your wheels or use spacers :P
R33's came with 16" standard. :O
its to do with the way the spokes are at the back of the rim, that determines if they will fit or not.
skyline brakes apparently need a 'high clearance' type rim, ie. one that the back of the rim is quite flat, or curves very close to the rim itself, not like alot of those rims that curve in to give them the 'dish look'
my rims only just clear gtr brembos and they are abit dished, but its the spoke design that allows clearance in the right area...
heres a pic of the clearance with my 17' rims... (i think its about 10mm max)
i find the brembos a great upgrade and very much worth the $$$ if u got reasonable horsepower and wanna stop safely :O
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
