hey guys, looking to get some wheels for my 32gtr, i understand you shouldnt run staggered sizing but how important is it that offset be exact? The wheels im keen on are 18x10 +10 and 18*10+4
As long as rolling diameter is the same it should be fine. Those wheels will stick out of the guards unless you run and negative camber.
Just copy and fill in the table;
Skyline model = R33 GTST
Wheel diameter = 18"
Wheel width = 10.5"
Wheel offset = 38
Tyre size = 265/35/18
Modifications to fit = fark all
please display a picture of te37 with that offset as im not too sure on what it is
Edited by DAV33R
18x9.5 + 30 will be safe. 18x8+15ish for fronts.. But I would just run 9.5+30 all round IMO. I am running 9.5+20 all round with no issues (but I am poking outside guards)
Edited by sleptema
Hello SAU, newbie here needing help. long story short, uncle is selling twin turbs BeeMerW and said that if his aftermarket 20"s that he had on it would fit my N/A 34 25GT, then i could have them. I'd just like to know if they would fit and if i needed to roll guards or adjust camber or anything like that. Also, if i would be able to lower the car if they did fit. I'm not condoning 20's on GT's but hey theyre free and have brand new low profile tred to go with them. Tried searching to find an answer but not really any luck, any help is much appreciated thankyou all in advance :cheers:
I'll probably just get the wheels off him when he's done with them, I just wanted to know if I would need to roll guards or anything like that
Listen to niZmO_Man, please, for the love of god.
He knows much more than you. Don't take what he said, then debate it.
Skyline model = R32 GTST
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +22
Tyre size = 235/45/17
Modifications to fit = Guards lipped prior to me owning so i can't really comment, scrub might be an issue if you are low, however i have no scrub problems
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
