Would 17x8 +28 with 255/40/17 tires fit on the front of a R32 GTS-T without rubbing the fender or impacting the suspension?
This question comes from an argument I had with a guy who claims it would be fine. However I want to be proven wrong.
I have a '98 R34 GT-T.
I had some Rota Grid 18x9.5 +35 and 18x10.5 +35 with 235/40 tires.
Fitment looked good but the fronts actually scrubbed on the inside suspension when turning too far. The 235's on the 10.5's were also a bit TOO stretched for my taste.
So I just installed some Work Emotion 11R 18x9.5 +20's all around and kept the 235/40 tires. The fitment looks perfectly flush with the rear fenders but sticks out considerably on the front. VERY aggressive but it DOES fit with stock fenders and doesn't scrub. Sticks out more than I was hoping but I do like it. I don't intend to roll unless I somehow end up scrubbing. I'm running stock GT-R shocks/struts.
Pics:
C225EEB7-3802-4046-AD97-10790DA7A23C_zps
81050FCF-1B5C-40F3-94CB-92EF96C008E1_zps
97E5D908-5A53-46C5-A43C-5771137A6314_zps
Car definitely gets more looks now. :)
  • 3 weeks later...
I'm sure this has been beat to death but after searching and not having luck figured this would be the thread to ask my fitment question on.
Have a 91 r32 gtst
Trying to run 18x9.5 +20 with 265/35/18 on all 4 corners. Is this going to rub like crazy?
Current setup is as follows:                                   17x7 +47 215/45/17 and 15mm spacer up front. 17x8 +47 235/45/17 in back
Edited by Ed.williams5
Hi all
Just bought an r34 gtt. Currently has 18x9.5+22 front and back with 235 to the front 255 to the rear. Tyres are pzero but have 30 % tread left on them, so is basically undrivable in 1st-3rd with 300kw and 885nm.
I have hks coilovers lowered with about a 2 inch gap from guard to tyres. Guards are all rolled too. Currently the front scrubs but I think this is on the loose inner wheel plastic guard (so I don't think I could or would really want to go bigger than 235 as I would need some more camber or raise the car)
With the new tyres im thinking of buying, can I afford to go for a 265 or 275 on the rear or will a good quality 255 suffice?
When I ask can I afford to go, obviously anything is possible, but would anyone have a photo of this so I can see what it would look like?
  • 3 weeks later...
  • 4 weeks later...
Guys please assist. Wheels and I just do not get along. Someone are good at it, I am not!
My r32 gtr is lowered on hks hypermax coilovers. Currently sitting on 17's with a 225 tire.
I want to purchase te37's preferably 18inch and be able to fit a wider tire. Nothing insanely aggressive, but proper looking.
I want 18's because I will most likely be upgrading the calipers and need them to fit. the stock brakes are garbage.
Also, no rubbing issues!
Please suggest.
Thanks
I'm not a noob, promise. Just suck with wheels
Edited by powerdbygarrett
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
