15inch 255/60 ET Streets.
I was taking it easy, I trapped only 133mph at Motive Drag Battle but I know the car is faster. I just to took it out to crack 140mph.
Runs were:
11.6 139mph
11.5 141mph
11.4 144mph
All were 2.3/4 60's.
  • Like 1
  • 4 weeks later...
  • 1 year later...
SETUP:
255 17" Hankook RS3
93 octane pumpgas (US = to RON98)
2.75L BC stroker
Ported head
Tomei poncam A
SS valves
Hypertune V2
BW 8374EFR IWG .92 divided
6 boost divided manifold
Nismo front LSD stock rear.
3176 lbs without me in it
NEW DATA:
93 octane (US) pumpgas (contains up to 10% ethanol)
60' = 1.772
330 = 4.837
1/8 mile = 7.363 @ 99.14
1/4 mile = 11.288 @ 126.26
OLDER DATA:
19 psi (20/sept/2016
Run 2 temp 72 degF
1.695 60'
[email protected] 1/8 mile
11.19@ 121.7 1/4 mile
  • 3 months later...
R33 gtst spec 2 auto.
hks mushroom intake
splitfire coilpacks
divorced wastegate turbo elbow
3" down pipe, de cat and cat back
gizmo ms ibc set to 1.03 bar
apexi safc-2
r32 gtst trust uprated side mount intercooler
mv auto's stage two quick shift kit with large mocal trans cooler
mapped at 296hp @ the fly but told by my tuner to get an emanage gold.
Toyo proxes r888's 255/50/16 on standard rims (23 psi in the rears)
tein springs
no nitros
Car seems to bog at the end of the strip suspected heat soak on my intercooler.
Edited by paulzy123
Forgot something
  • 4 months later...
R32 GTR
Forged 2.6L
Garret -5's
HKS F-Con V
Tomei Cams Type B (Pon)
All the normal stuff - dump pipes/exhaust etc.
Suspected Leaking BOV as I can here something leaking.
11.9 @ 116mph with me hitting the rev limiter in 2nd (oops).
Time to replace BOV and run again!
17 hours ago, Stixbnr32 said:
R32 GTR
Forged 2.6L
Garret -5's
HKS F-Con V
What boost level and fuel?
BP 98 and 21 PSI was 373KW atw.  But I can hear a leak so not sure what it was at the time - I think it is my BOV so looking to replace and run up on dyno again to make sure all is well.
R33 GTST s2
ET:13.9
MPH:105
60':2.4 shocking start only got one run rained out
FUEL: caltex vortex 98
TYRES: triangle 235/45/17 very hard
Power: 210kw 16psi small mtq highflow turbo
Going back in afew weeks to better my et and 60ft
Fix std bov bleeding off over 1bar and upping to 18psi boost
Also gonna put on some mickey thompson et streets 255/50/16 i got on 300zx stockies
  • 5 months later...
  • 3 months later...
  • 4 weeks later...
Z32 300ZX
1590kg race weight
E85
Stock turbos
Restrictive exhaust and intake setup
1000cc injectors
R32 GTR 4.11 diff
Intercoolers
Nistune
Blown rear shocks causing extreme tramp.
ET streets 255/60/15
300rwkw @ 15psi on unigroup dyno.
12.4 @ 116mph, 2.1 60ft.
Have coilovers in the rear now and a wizards of nos sb150i2 nitrous kit fitted so will go back to crack an 11.
  • 1 month later...
  • 3 months later...
  • 1 month later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
